GT4 RS Strut tower failure...
The following 2 users liked this post by TRZ06:
DFW01TT (04-01-2024),
SpyderSenseOC (03-31-2024)
Nope 718 has the same issue just not as common as the 981. Pretty much went away after people stopped slamming their 981 GT4's. Still a hard hit bottoming out the suspension or bad pothole is still a concern.
Peter
Peter
The 718 has basically the same front tub as a 981&991..
The 992 has a totally different tub and strut towers.
That’s one of the first things I looked at when I decided to get a 992
the 992 towers are much more robust and reinforced, but still cast aluminum
I always thought an easy remedy was to have a stamped steel insert underneath the Strat tower installed from the bottom.
I don’t know why somebody hasn’t made one wouldn’t be hard 1/16 stamp steel would do it.
The following 2 users liked this post by Alan C.:
Le Petit Garage (04-01-2024),
vg247 (04-02-2024)
4carl (04-01-2024)
From: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
Del
The following 5 users liked this post by TXshaggy:
cooler2442 (04-01-2024),
Larry Cable (04-01-2024),
Mike981S (04-02-2024),
wizee (07-17-2024)
The tower is bonded-in cast alu part… so it can be removed and new one bonded back in. Porsche have a specific known repair process so not a ‘major’ issue aside from damage to any other components that might also need to be replaced as a result of the impact.
The following 4 users liked this post by TDT:
The following 2 users liked this post by cooler2442:
Is that stock suspension?
Also, I don't see any strut tower "failure", I see an anecdotal 10 ft view of what may be damage caused by something else that impacted that area, not necessarily stress related fracture.
Tay101 (04-01-2024)
Huh... so the take away? the $RS has more horsepower and faster in a straight line? And if you buy some stickier tires a GT4 will be faster in the corners.... Thanks @TRZ06 you just saved me $100,000!
HAHA, yeah the rest of the video was more of a DUH, but I found the strut tower thing interesting as it's mostly unheard of on the 982 chassis.
dnimi123 (04-01-2024)
The following 2 users liked this post by ExMB:
lovetoturn (04-01-2024),
