Forest Green Metallic 997.1 C2 - A build thread
I thought that it would be better to open a thread and keep track of what I did to my car instead of posting here and there and resurrecting old threads
I'm based in Barcelona, Spain, and in January I blindly bought a car from an island called Mallorca. It was a cheap car so I took the risk and bought it before being able to inspect it. I flew there, got the car and brought it back home by ferry the same day. The risk paid off as the car is solid, but wasn't looked after. Nothing I can't fix, and I love a project car more than a pristine condition one.
At its new home
2005 911 Carrera 2 in Forest Green Metallic. 141.000km (~87.000 miles). I'm the second owner. Options include (sorry, in Spanish):
I drove it straight to my mechanic and he performed the following operations:
- Replaced spark plugs for NGK Iridium ones
- Replaced oil (5W40 Castrol Edge)
- Replaced oil filter
- Replaced transmission fluid (Motul Gear 300 75W90)
- Replaced coolant reservoir (it was leaking)
- Replaced Poly belt
- Replaced pulleys
- Replaced a leaky (and expensive) coolant pipe
- Replaced brake fluid (Motul RBF660)
- Added steel brake lines
- Replaced brake pads for Ferodo DS2500
- Replaced worn engine mounts with Function First
- Replaced the thermostat for a low temperature one
- Replaced the water pump
- Bomba de Agua
- Flushed the coolant (G12 Evo)
With all this done, I feel I have a good base car to start working on. I'ts not perfect by any means, I still need to replace the clutch and other various things, but at least I can drive it for a bit without worrying.
At its new home
- Replaced pulleys
- Bomba de Agua
The following 7 users liked this post by smrpr:
BRN9121 (04-30-2024),
evil_betty85 (03-13-2024),
ftc3 (03-13-2024),
Graufuchs (03-12-2024),
JAAM (03-13-2024),
and 2 others liked this post.
Stuff I've done as of today:
When I first opened the sun visor, the cover of the mirror fell on my lap as the plastic melted:
I was going to order a genuine Porsche one until I saw the price:
So I resorted to Aliexpress
30 second fix
Lots of the plastics were very worn so I gave them a bit of Meguiars love:
Also installed the auto headlights mod from 997Research:
Replaced the fog lights for a set of 991-style DRLs:
And the side markers, too. These are a set of Audi-style sequential lights that I'm still not sure if I like:
Got my cat to approve the jobs I was doing on the car, she said all looks ok:
And I installed a Macan steering wheel together with the steering wheel column from a 997.2 that supports the multifunction:
I have an issue with the steering wheel as it rubs on the steering column when doing 90 degree turns and it's driving me crazy. I really need to fix it but I'd rather not take everything apart again.
This is how it sounds like: https://i.imgur.com/l598ylb.mp4
And I found an old thread with exactly the same issue: https://rennlist.com/forums/991/1360...s-rubbing.html
I'll need to look into it but very happy with the new wheel otherwise.
30 second fix
The following 4 users liked this post by smrpr:
Stuff that's pending:
Fister mod on a stock exhaust that I found for cheap and spent a week cleaning up:
Before
After
Install 200-cell cats and equal length headers that I got from TopGear UK:
And most importantly, I need to drive it and take some good pics of it! Haven't even driven it 200km since I got it and I hope this weekend I can fix that.
Before
After
Wow, looks like you had a clear plan and are executing it!
Congratulations, love the colour - don’t see Green 997’s too often.
Benlavigne (03-12-2024)
Great to see how you're improving this car. And quite a unique color as well!
If you experience notchiness in the shifting, please note that many consider that Mobilube PTX is best when changing the transmission oil.
smrpr (03-13-2024)
The following 6 users liked this post by smrpr:
Carrera2RS (04-29-2024),
Graufuchs (03-13-2024),
myw (03-18-2024),
Spastblast (03-14-2024),
and 1 others liked this post.
