718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Can't downshift from 3rd to 2nd gear? Tranny oil problem?
Old 10-12-2021, 08:37 PM
McMGC
McMGC's Avatar
Default Can't downshift from 3rd to 2nd gear? Tranny oil problem?
Was at Sonoma track the past Sunday. About 10 minutes into my 3rd session, I suddenly wasnt able to downshift from 3rd to 2nd gear. Gear just refused to go in.
The first two sessions were great, and this never happened in the last 5 track days this year.
Came off track and everything was normal again.
Has anyone experienced similar problem?
Old 10-12-2021, 08:41 PM
Alan C.
Alan C.'s Avatar
Received 1,033 Likes on 532 Posts
Could be a shift cable/linkage issue assuming it’s a 6 speed.
AlexCeres (11-06-2021)
Old 10-14-2021, 05:09 AM
McMGC
McMGC's Avatar
Is this common in a low mileage car?!
Old 10-14-2021, 10:06 AM
blraider97
blraider97's Avatar
Not uncommon. I had one. Of the shift cables snap at a relatively low mileage but I’d have to look to see exactly when it occurred.
Old 10-14-2021, 11:22 AM
BillC3
BillC3's Avatar
Yes, it's happened before (at least 2 other threads on RL about this), and it's a driver issue not a car problem.
What's happening is that you're getting too enthusiastic bringing the gearshift lever over to the 1-2 channel and blowing through the reverse-block detent. At that point, you are in the reverse channel, and can't pull the lever back because there's no gear there.
If you don't believe me, try this: Sit in the car, move the shift lever to the left slowly and then into the reverse channel. That reverse-block seems very stiff, right? Now, move the shift lever all the way to the right and quickly move it left into the reverse channel -- if you do it "right", you'll blow right through the reverse-block like it isn't even there. That's what happened to you on the track.
Try shifting a little more gently and with your fingertips/wrist instead of your whole arm -- you'll be able to feel what you're doing better.
The following 3 users liked this post by BillC3:
fueledbymetal (10-18-2021), McMGC (10-14-2021), theEnd (11-06-2021)
Old 10-14-2021, 11:30 AM
phefner
phefner's Avatar
What @BillC3 writes makes sense. One the guys in another thread posted this interesting ATI. Worth having a look.
The following 4 users liked this post by phefner:
AlexCeres (11-06-2021), DFW01TT (11-06-2021), fueledbymetal (10-18-2021), worf928 (10-14-2021)
Old 10-14-2021, 11:37 AM
Larry Cable
Larry Cable's Avatar
Received 3,586 Likes on 2,333 Posts
I wonder though would the subject of the ATI be "transient" - i.e happen occasionally as with the OP?
Old 10-14-2021, 11:43 AM
phefner
phefner's Avatar
Yeah, failures I've read do seem like they are either connected or not connected. Good point sir.
Old 10-14-2021, 11:45 AM
Larry Cable
that being said, I'm still a little in shock over PAG recommending resolving a shifter cable issue with tie wraps!!!
I think if this happened to me, I'd be looking at some Numeric cables ...
Old 10-14-2021, 12:06 PM
phefner
phefner's Avatar
Yessir...Numeric's on my list for upgrades next season. Along with a dedicated set of track wheels, and potentially a new exhaust to open it up a little more. Did and like my Akra OAPs.
Old 10-14-2021, 12:15 PM
BillC3
BillC3's Avatar
If the car goes back to normal after coming off the track, as reported by the OP, then the problem isn't the shift cables. Plus, a cable breaking or coming off presents a different symptom: the shifter flops around in one axis (or both, if both cables break or come off), not refusing to go into gear like the OP said.
Old 10-14-2021, 01:06 PM
Larry Cable
Yeah sounds like a "better" fix than a couple of tie wraps - albeit a little costly!
Since I forked out for "wheel" insurance I feel obligated to use the OEMs for track!
yeah that's what I thought too...
Old 10-14-2021, 03:57 PM
McMGC
McMGC's Avatar
Dont want to admit but this sounds very logical and reasonable
I am doing my first free oil change today and my dealer is going to check if there's any fault code. Probably none though. Will report back.
Old 10-16-2021, 02:51 AM
GT4_trip
GT4_trip's Avatar
seems like a numeric shifter may be your solution. Even with the standard spring, it’s difficult to accidentally go into reverse.
Old 11-06-2021, 12:47 AM
csg76
3rd Gear
csg76's Avatar
Did you find anything at the dealer? I was at Sonoma today for my second track day with my new (to me) 2020 GT4 (manual). On the fifth run of the day, right out of the pit, I couldn't downshift to second gear in the first corner (from third, at 3k RPM). It felt like there was a plastic/rubber stopper in the way. I shifted back to third, carried on, and then had the same issue on turn four, at which point I exited the track. I was unable to get the issue to happen off the track. I went back out for one more lap and had the same thing happen again on turns two and four. On the drive home I tried downshifting from third to second at 40, 50 and 60 mph, and had no trouble with any of those. All of this was with auto-blip enabled, by the way.
I'm coming back to driving a manual after a fairly long hiatus, so this could definitely be user error, but I'm struggling to understand how I wasn't making that error the rest of the day, or why it suddenly worked fine when I was off the track. In any case, I'd be very curious to hear what you learned from your dealer. I'll be calling mine on Monday.
Quick Reply: Can't downshift from 3rd to 2nd gear? Tranny oil problem?
