Flawed understanding of smoking 993TT turbochargers
That being said, this theory never really made sense to me. Every performance car I have owned has been turbocharged. I'm not a professional mechanic but have built turbocharged vehicles for 20 years. I've never before experienced any other turbocharged vehicle where oil under gravity feed can bypass the turbocharger oil seal. The CHRA is fed pressurized oil in plain bearing turbos and don't leak so how can oil fed by gravity leak past the seals even if the sumps were backed up? On initial startup, the turbine housing is cold. Even if it were coated in oil, it shouldn't smoke until it gets to operating temp. 993tt's that are smokers blow a consistent puff of smoke right on startup before the turbine housing gets hot. This must be coming from the combustion chamber and not from oil leaking into the turbine housing.
With this in mind, I can say my 993tt has been a chronic smoker from the passenger side turbo. I finally decided to investigate and fix it. After a long drive I parked it for weeks. I can almost guarantee smoking on startup in my car if parked for a few weeks. After waiting a few weeks I pulled the exhaust (easy since my car is straight piped) to inspect the turbine housing. No oil in the housing even looking with a scope between fins at the bottom of the turbine housing. Starting the car, I get smoke. This implies the smoke is not coming from oil burning off in the turbine housing. Starting the car after inspecting the turbine housing I get smoke. This implies the smoke is from oil burning in the combustion chamber.
Step two I pulled the turbo sump breathers and vented them to atmosphere. No smoke whatsoever. Reconnected them and I get smoke. I then adapted a clear plastic container which I fitted between the turbo sump breather hoses and its regular connection to the vacuum nipples just past the mass air sensor. On starting the car I get a small slug of oil being sucked up the turbo sump breather hose which is then dumped into the plastic container. The plot thickens...
In short, I theorize that our understanding of turbo oil smoke may be flawed. In my car it does not seem to be burning off in the turbine housing. I believe it is backing up in the turbocharger sumps, and ending up in the sump breather line. On startup, vacuum in the intake is sucking a small amount of oil up the sump vent hose, which then travels through the intake piping, turbo compressor housing, and intercooler and burning off in the combustion chamber to cause the smoking on startup. This also accounts for why folks see oil in pre turbo intake piping and intercooler.
It seems that running a lower oil level, check valves, correct small oil filter and P trap scavenge lines reduce the chance of oil backing up in the turbo sumps which therefore reduces the incidence of smoking on startup. These are all reasonable fixes. I'm still cynical of the idea that carbon build up from oil leaking into the turbine housing will destroy oil seals by "cutting them like diamonds". Turbine shaft oil seals are not soft rubber/synthetic. They are steel and many report smoking with newly rebuilt turbos even after upgrading to step gap seals. Coking of seals from hot shutdown is well described as is severe coking when excess oil pressure is run due to poor restrictor sizing however gravity fed leakage is not well described. Clearly I'm not a foremost authority on this topic and don't have all the answers however this is my experience on my car. Hopefully others will chime in and we can develop a better understanding of this issue.
I fought startup smoke for 18 months, following all the suggested solutions you mentioned, including rebuilding both turbos two times. Nothing I did fixed the problem. Finally, I figured out that oil was migrating from the sump to the intake manifold, via the sump vent hose. I did an experiment to confirm this.
Opening the sump vent hose to atmosphere (and plugging the open hoses on the intake manifold) solved the problem. If you have smoke on startup, I believe this easy and reversable fix should be the first thing to try.
It seems the only sensible source for oil in the pre turbo plastic intake pipes is either from crankcase blow by or from the turbo sump vents. Blow by oil should just be a light oil film unless the engine is on it's last legs. The only real source of large amounts of oil in the intake pipes therefore must be from the turbo sump vent lines.
I will post a picture of the burnt oil/solid carbon built up in the turbine/bearing housing heat shield..
Any chance you can explain how the intake pipe is often filled with oil? I figure that the volute of the compressor housing would have to be half filled with oil before it spills into the plastic intake pipe.
"If exhaust gas pressure pushes past the exhaust seal it will simply vent into the oil return/crankcase."
Turbine side seal (piston) ring failure will push oil past the compressor side seal and into the intake inlet piping (first) and then into the compressor housing, intercooler, back thru the bypass diverter valves and recycled back to the inlet piping and compressor housing.
Here, look under "oil leakage at compressor
https://www.borgwarner.com/aftermark...roubleshooting
Oil scavenge issues
Turbine Piston ring failure OR high crankcase base pressure (ie bad valve guides , piston rings)
I'm no expert in turbo rebuilds but have disassembled a few. My understanding is exhaust gas that pushes past the turbine oil (aka piston) seal will vent into the oil return chamber of the CHRA. I stole a cutaway diagram of a turbo to reference below. Exhaust gas that pushes past the turbine oil seal on the red (turbine) side will feed into the oil return chamber in the center of the CHRA. This chamber is not pressurized and in most cars feeds the engine sump. The only pressure it sees is crankcase pressure which should be minimal. In the case of the 993tt this oil return feeds the turbo sumps which are emptied by the scavenge pump. Even if exhaust gas pressurized the red (turbine) side bearing, it would just push oil out of the bearing and into oil drain. It would only be if the oil drain was blocked (ie scavenge pump failure or high crankcase pressure) that the oil return chamber would fill with oil and then potentially push past the blue (compressor) side seal. Most of these 993tt's that smoke are otherwise healthy engine wise and have working scavenge pumps and not a ton of blow by. In these cases I can't see how turbine seal failure would push oil out of the compressor side oil seal. I must be misunderstanding something..
993tt got turbos rebuilded, but always the one that smoke through the tail pipe is the left turbo (right side pipe).
This is what we have done so far:
- Check valves installed (oil feed) long time ago
- Custom return lines with check valves, long time ago
- New OE oil filters, not fully torqued (small one) , tried with hands only and later (change of oil) with the torque specified on the filter ,( long time ago and recently did again a new oil filter change)
- Mobil One V-Twin 20W50
- Oil level below mid section of of the machined part of the dipsticks ALWAYS
After a chronic leak on the left rebuilded turbo, we opted to buy a NEW borg warner turbo that came from europe. Installed and seemed to not leak, yet it was smoking, perhaps oil pools still inside the exhaust system burning....then after a few drives, the smoke went away and seemed to be all fine and fixed. Days later it started to smoke again at the tailpipe (left turbo-right side pipe), also noticed slight leak of oil between the cartridge and turbine housing and exhaust turbine side & exhaust tube (downpipe) and very little leak in the compressor side as well. You could see some oil cooked between the cartridge and housing as well. Cleaned it and took for s another spin and smoke went away. Figuring the "turbo did a break in" and self sealed the rings....after a few days of use, the owner started to get tons of smoke (left turbo -right side pipe) again and flood of oil in the exhaust.
Then we decided to clean everything again, and tested the left turbo scavenge pump, by disconnecting the sump return line and hook up it from a clean can of its own oil and transparent line to check and confirm the oil was being sucked into the scavenge pump and was working fine. Then took for another spin to clean up all and was fine. The next few days started to smoke badly again. This time ,after trying to cure with engine running the remaining oil in the exhaust, found a chunk of oil (not the first time I have seen this though) while taking apart the left turbo INTAKE tube (see video): After this I decided to inspect the turbo sumps vent lines.
The vent lines were free of clogging , flowed perfectly. I studied the line and they has in each side a T connection, one goes to a CHECK VALVE that is fitted BEHIND the throttle body, which prevents to pressurize the turbo sump vent line from positive pressure (when turbos kick in) and the check was perfect working as we took it off and tested outside. And the T lines continues at the back of the "Y" or elbow for the intake of the turbo, just behind the MAF sensor, all were free flowing, because at some point I thought it was clogged or somehow it was pulling too much vacuum and the oil from the turbo sumps were sucked and dumped in the intake side (I even video scoped the left side and I could see a thin oil film in the intake tract of the "Y" but couldn't be sure or precise if it was all coated in oil which seemed to not be the case (as why I got such chunk of oil from the left turbo intake pipe in the video).
We also did compression test and made a "Y" fitting to read oil pressure at the top of the turbo oil feed in each turbo as noted in the below photos
Now...we are going to re-install the rebuilded old turbo from the left side (which is sitting in the box, as it was replaced for a new turbo) and will install it in the right side, and see if it leaks like it did in the left side and report back. I have even run the engine with the turbos downpipes off and the left new turbo, cured the remaining oil into the exhaust turbine (as photo shown) and didn't leak anymore......WEIRD.
VIDEO url https://www.youtube.com/watch?v=va_q...ature=youtu.be
Pete
Yes, these tests are being done with the turbo sump lines VENTED at the atmosphera. We have switched between rebuilded turbos and the new turbo, all tested in the left side (and from right to left side as well, i.e. swapping them fromside to side) and always leak the left turbo side ONLY. Right side is perfect. We even lowered the custom scavenage pump return pipe with check valve, so it seats at the same level or lower than the turbo sump ventilation line of the sump, as we thought it could do something with it being higher than it. No luck..
Honestly, I'm running out of ideas at this point....
I hear you, I know how much oil collects inside the exhaust (CAT & MUFFLER) and take good time and few hard runs to fully cure or get rid of the smoke. But in my case the left turbo is still smoking/leaking badly. Today I applied a old "technique" I used in my early turbo conversion engine (BMW m20) I did many years ago, added a valve to regulate the oil pressure going into the turbo that fixed the smoke/leak in that engine. I have set the oil pressure lower and I will keep testing and see if still leaking oil (seep) through the turbine exhaust and center section plus through the turbine wheel.
I have concluded that the severe leaking (left side always) only happens when the engine is left resting after fully working hot condition. So, parked overnight, next day you will find all the oil in the compressor side (like the pic below) , but not ALWAYS such amount, leak through the exhaust turbine and drops of oil in on the sump as well as previous pics shows in earlier posts.
The first photos were PRIOR to the next following test described below (So you can see how bad is the oil in both sides)
Then we cleaned all, installed back in place and after running the engine, we left it to rest and installed in our "Y" connector, a empty bottle can to collect any possible RESIDUAL PRESSURE left in oil system and here is a data we collected:
Hour ---------Oil in ML
11:30---------- 0
12:05 ----------200
12:35 ----------250
1:25 ------------350
2:10 ------------375
2:40 ------------400
3:10 ------------425
3:45 ------------450 +
First pic bottle full and had to dump it into the quart bottle to keep checking if more oil would keep comming out of the oirl pressure system (oil turbo feed line)....and second pic shows waht extra oil dumped and that was all.
Then we moved our "Y" fitting into the right turbocharger and did the same test. We left engine rest overnight , ran the engine and we collected the following data (Keep in mind this time the left rubo didn't leak a drop of oil maybe because the RESIDUAL PRESSURE was released in the right head/turbo side ?
Hour -----------Oil in ML
10:00 -------------0
10:35 -------------200
11:05 -------------250
11:35 -------------275
12:05 -------------300
12:35 -------------325
1:35 ---------------350
2:05 ---------------375
4:45 ---------------400
So right side turbo , as you see, does recieve residual oil pressure as well, YET, the turbos (03) tested in that side NEVER leaks which is very confusing. By the way, turbo sumps breathers were connected to the intake as factory in these last test we made.
Any ideas?
