Fuel Tank bracket repair
Old 05-22-2019, 08:35 AM
SRaouf
SRaouf's Avatar
Default Fuel Tank bracket repair
Hello
The small bracket at the top of my fuel tank seems to suffer from a slight corrosion problem. Anyone successfully repaired this in the past?
Old 05-22-2019, 08:51 AM
C531XHO
C531XHO's Avatar
Originally Posted by SRaouf
Hello
Haha its in my near future too. It's an aluminium flat plate that has multiple (4?) "hooks" on the bottom edge that slide into holes in the tank top. There is a single hole for a bolt at the top. What I don't have is a full pattern, just maybe more left of my original. Don't know if these are available new?
Old 05-22-2019, 09:04 AM
SRaouf
SRaouf's Avatar
Its not listed as a seperate part in the EPC however if there is a way of removing and fitting it to the tank without damaging it then shouldnt be too hard to fabricate.
Old 05-22-2019, 09:37 AM
C531XHO
C531XHO's Avatar
You could make 2...😜
Old 05-22-2019, 10:24 AM
SRaouf
SRaouf's Avatar
If I can figure out what it looks like and how to remove/fit it I dont mind knocking up an extra one.
Old 05-22-2019, 10:31 AM
C531XHO
C531XHO's Avatar
I was being cheeky. If you can figure out the details I will follow. Oh for a CAD system, 316 and a laser cutter..
Old 05-22-2019, 10:42 AM
Hymodyne
Hymodyne's Avatar
Default made a new one
fabbed a replacement from 16 Gauge sheet metal. covered with rubberized coating and attached it to the remnant of the original. I'll send a picture when I'm home from school tonight.
James
Old 05-22-2019, 01:49 PM
soontobered84
soontobered84's Avatar
Is it salt that is eating your brackets? I notice that all who have responded are from the colder climes.
Old 05-22-2019, 01:54 PM
Ninespub
Ninespub's Avatar
They're all from the land that drives on the wrong side of the street.
Old 05-22-2019, 02:19 PM
soontobered84
LOL. I saw that Paul, but in these times of Political Correctness, I didn't want to seem to poke fun at the Eastern hemisphere.
Old 05-22-2019, 04:11 PM
SRaouf
SRaouf's Avatar
Yes salt is the main culprit. if you think thats bad you should have seen the rest of the car when I got it.
James adding metal to the remnants sounds like the best solution as I can cant see how to get the old one off and bond a new one in without using heat which may damage the tank
Old 05-23-2019, 04:47 AM
C531XHO
C531XHO's Avatar
It looked something like this from memory
Bit like a Mister Man..
Old 05-23-2019, 05:20 AM
SRaouf
SRaouf's Avatar
Thanks Ill have a look at this in the next day or so once Ive got the rear subframe back on
Old 05-23-2019, 05:38 AM
DuncanF
DuncanF's Avatar
I'm sure this has been discussed before on here so this may help ...
https://rennlist.com/forums/928-foru...nt-insert.html
Regards
Duncan
Old 05-23-2019, 06:32 AM
SRaouf
SRaouf's Avatar
Regards
Duncan
Thanks very helpful where are you in surrey? Im in Walton-on-Thames (near Brooklands)
Quick Reply: Fuel Tank bracket repair
