944 4V
Old 03-21-2018, 05:56 PM
michaelmount123
michaelmount123's Avatar
Default 944 4V
Ran across this photo from back in the day when upgrading from 2V to 4V via a 944S head. No, the pan didn't work, nor did the (restrictive) air cleaners. Cobbled together an intake manifold to accommodate 55mm Weber carbs and had to put a bubble in the hood to clear them. It was a 2.7L to fall into a PCA GT class back then. Made over 300hp; later iterations made 330+. Shifted at 8000. I know, I know, no turbo. But it was running in front of those pesky boosted GT cars....
Old 03-21-2018, 10:08 PM
David Floyd
David Floyd's Avatar
Bet that was a wicked sound at 8K
Old 03-21-2018, 10:56 PM
refresh951
refresh951's Avatar
Very cool! What year was this?
Old 03-21-2018, 11:52 PM
Humboldtgrin
Humboldtgrin's Avatar
My story is that was a Lemans replica head made back in the spring of 82. MM hand machined it using pre CNC machines and finger files. Then he gave it a factory cast appearance somehow. It's actually all made out of a solid block of unubtanium even the valve train. Or that's the one that was a replica to that one I mentioned but it was made sometime later.
Old 03-22-2018, 03:17 AM
V2Rocket
Rainman
V2Rocket's Avatar
did you do anything internally to mitigate the balance shaft delete, or just check everything frequently?
longer rods perhaps?
Old 03-22-2018, 08:25 AM
Noahs944
Noahs944's Avatar
Amazing work!
Regarding the oil pan, did you end up going back to oem for this engine? Or dry sump?
Old 03-22-2018, 01:59 PM
Paulyy
Professional Hoon
Paulyy's Avatar
But Bob Norwood...
Jokes aside, I like where you went with this. 330hp is a good amount!
Old 03-23-2018, 05:31 PM
333pg333
333pg333's Avatar
Why didn't the pan work Michael?
Old 03-24-2018, 04:18 PM
michaelmount123
Had to go back and find the photo to get a date: Sept, 1994.
I never ran balance shafts, and never had a discernable engine vibration. Yes, I Loctited all the fasteners (would have anyway), and kept an eye on bracketry and what not. Internally, 1/16NPT plugs to block the balance shaft oil feeds and capping the front of the balance shaft housings are all that's needed. No balance shafts was part of my KISS principle, and I never experienced a downside.
The pan was designed by a big-time pan fab shop (see decal). They told me they learned from NASCAR that the oil was always thrown to the right side due to crankshaft rotation, so pick-ups were only needed on that side regardless of G load. The pan in the pic had internal tubes to the passenger side. Who was I to dispute their experience? A few crankshafts later, I confirmed the oiling problem by shutting the engine down at full song and immediately pulling a scavenge line off the pan. Found the pan FULL of oil when it should have been empty. Guess they were wrong... I redesigned another pan with scavenges on both sides (using a stock wet sump pan), and an internal baffle and never had another problem. Live and learn. I've got pics of that pan somewhere if anyone is interested. I also used a crank scraper. BTW, I found that 8000 was okay with the dry sump 944, but lost one big time shifting at 8500 (rod bearing failure, chucked a rod). I've gotta believe the issue is with crankshaft oil passage design from main bearing to rod bearing, but I never pursued it.
Old 03-24-2018, 07:17 PM
gruhsy
gruhsy's Avatar
Pics on pan yes please.
Do you think your rod bearing mod would have helped out in the 8500 rod failure?
Old 03-25-2018, 12:56 PM
jimmerp
jimmerp's Avatar
X2 on the pan pictures please!
Old 03-25-2018, 01:28 PM
Humboldtgrin
Why would you want photo's of something that didn't work? How about photo's of a real dry sump pan. Or anything MM has designed or put together(now those are the photo albums we all want to see) or any other cool parts we all know he has laying around. Of course MM's rod mod would have saved that engine if that was a stock oil pan. Or an oil change and a stock oil pan.
Old 03-25-2018, 03:49 PM
gruhsy
gruhsy's Avatar
I believe you miss read. The pic we want to see is the second oil pan Michael designed that worked....the first pan was the one that didn't work. The failure at 8500.....if I am interpreting properly what Michael said was due to the crank oil passage not the second pan design.
Old 03-25-2018, 03:50 PM
ealoken
ealoken's Avatar
Originally Posted by gruhsy
I believe you miss read. The pic we want to see is the second oil pan Michael designed that worked....the first pan was the one that didn't work. The failure at 8500.....if I am interpreting properly what Michael said was due to the crank/oil pump combo not the pan design.
the oilpump cavitates (air in oil) above 8000 Im told.
Old 03-25-2018, 03:54 PM
gruhsy
gruhsy's Avatar
That may also depend on oil type/viscosity I suspect.
Quick Reply: 944 4V
