Mounting Schro 6 point harness in Cayman GT4
I have the factory Carbon seats and cage. The belt came with 4 bolts but how do I mount shoulder harness points (2) to cage. Do I need an extra bar or some mounting to go on the bulkhead behind the seat.
I was actually just going to post about *which* 6pt to install. Is everyone here using the GT3 Schroth belts https://www.schrothracing.com/produc...sche-harnesses or the Profi IIs?
I'm getting my Harness installed this week, we are using the BBI sub mount hardware. I purchased mine through Cobb.
https://www.cobbtuning.com/products/interior/bbi-autosport-porsche-cayman-gt4-981-sub-belt-bracket
If you ordered the Schroth GT3 belts, they already come with the proper end attachment for lap belts to connect to the LWB seat. Scroth's websites indicates there is no modification needed, and the tech that installed my set up, which is identical to yours, had no issues.
I think the Cantrell sub bar is a better solution. I'm switching from the BBi to Cantrell this spring.
