How can I get rid of the discoloration remaining after wet sanding
I wetsanded a few areas on this door and as you can see the wetsanding has left discoloration spots.
I sprayed water to clean it off but once dry the discoloration remains.
How can I get rid of this?
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
I believe that was a joke sir. What grit did you use? if you used anything less than 2k, it's very possible that you went straight through the clear, in which case, your only solution is new paint. Also, what kind of car is that? Definitely not a Porsche haha
wow what a kickass maserati
Why not just hit it with more flat black single stage? What are you trying to do, gloss up flat black paint? Painting is easier than sanding (said the previous owner of your truck).
Is "dumpster paint" a thing?
