Right Rear Fuel Smell! '88 S4
Old Oct 14, 2008 | 08:13 PM
no doubt's Avatar
no doubt
Default Right Rear Fuel Smell! '88 S4
Walking around my shark after shutting off the motor I noticed a fuel smell from the right rear wheel-well area.
So I tore into it, expecting to find a cracked hose, loose hose-clamp, untight fuel check valve, failed fuel filter or fuel pump, etc.
Nope.
Here's what I found, instead! Gee, thanks prior owners! 5 holes from what looks like a speaker or upholstery installation on the cheap.
Broke out the JB Weld after cleaning the expansion tank. Cold welded the holes shut.
Drove around for an hour. Stopped my shark. No more fuel smell (for now!).
Enjoy the pic.
File Type: jpg
Old Oct 14, 2008 | 08:50 PM
karl ruiter's Avatar
karl ruiter
Some people should have a manditory cooling off period prior to being allowed to purchase a drill motor. Not to mention a background check.
Old Oct 14, 2008 | 09:06 PM
SeanR's Avatar
SeanR
Are those holes through the rear deck?
Old Oct 14, 2008 | 11:20 PM
no doubt's Avatar
no doubt
From somewhere inside the cockpit down into the fuel expansion tank, but it's not obvious from the inside specifically "Where" the errant holes originated.
Old Oct 15, 2008 | 01:17 AM
mark kibort's Avatar
mark kibort
I did the same thing when i was cutting out some of the steel around the seatbelt mounts. I nicked the fuel expansion tank and had that gas smell when ever i had more than a half of a tank , or if i was racing, it would leak arouund the inside and i had no idea where it was coming from. finally, checked out the expansion tank and there was the cut. Jbweld did the trick.
mk
Old Nov 13, 2008 | 08:03 PM
no doubt's Avatar
no doubt
JB Weld is still holding a month later!
