Removing Camshafts and Heads
Old 10-26-2017 | 07:27 AM
ammonman's Avatar
ammonman
Being this is an S4 motor it will use bolts, not studs. Buy new bolts from Porsche and proceed worry free.
Mike
Old 10-26-2017 | 08:35 AM
SwayBar's Avatar
SwayBar
Yes, good advice to replace chains and tensioner pads.
An S4 has head bolts, and you can reuse them at least once. I'm sure some will state otherwise.
Old 10-26-2017 | 02:28 PM
Ricardo Vega's Avatar
Ricardo Vega
OKAY! sounds great guys! I truly thank you all for the wealth of info. Looking forward to progressing in this very intricate project. I'll keep everyone posted on where I'm at. Thanks.
RV
Old 10-27-2017 | 10:07 AM
Wisconsin Joe's Avatar
Wisconsin Joe
Originally Posted by Ricardo Vega
M28/42, what do those numbers mean?
Engine designation.
All 928 V8s are "M28" motors. The 2nd number is the specific engine, with odd numbers being manual trans and even numbers (like yours) being auto trans.
Link to a chart that shows them all:
http://928gt.com/t-928engine.aspx
Old 11-03-2017 | 02:37 PM
Ricardo Vega
Hey guys so I was able to remove camshafts, chain, and removed head to only the driver-side for now. I'm just posting an update and some questions for you guys about what I'm seeing on the heads and pistons.
There's alot of build up on the heads, both intake portions and exhaust sides, and tops of pistons have a thick layer of black build up on them. By the way, I will post pics so you guys can see.
So first question, is that build up caused by the oil that engine takes in? When I removed intake there was so much oil inside of it. I need to fix that issue too but first this. Or is that carbon build up normal?
I know I have another couple of questions but I have to book it to work so maybe later.
Thanks.
RV
Old 11-03-2017 | 02:39 PM
Ricardo Vega
Old 11-03-2017 | 02:40 PM
Ricardo Vega
Old 11-03-2017 | 02:41 PM
Ricardo Vega
Old 11-03-2017 | 02:43 PM
Ricardo Vega
Old 11-03-2017 | 02:45 PM
Ricardo Vega
Quick Reply: Removing Camshafts and Heads
