2020 NEXT GENERATION 992 SPY PICS & RELEASE
#631
![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
#634
Originally Posted by Zlaatan
Spot on. All these active wings that sits flush with the body when in the down position look terrible when they come up imo. Aventador, SLS, AMG GT, F-type, 911, 720s, A7 etcetcetc they all look like a part of the body has come loose when the wing goes up and I can't stand the look of it.
I get that it's functional and helps performance, especially on supercars, but the cars look just like you said, broken.
#636
Looks like an evolved 991, with retro references in the hood, and with larger diameter rear wheels than front. The flares are sweet. Looks like all grip n go for the new understructure and what must he boost in HP to stay competitive with its rivals. I'd guess the weight distribution is improved too.
I hope that larger spoiler is a significant aero improvement, because it does nothing good to the rear look when deployed. A Panamera Turbo sort of spoiler should be an option.
#638
Lift goes up, downforce goes, well, down.
But yes, the downforce is the result of lift being generated by an inverted aerofoil and it's alpha, angle of attack, chord and NACA shape and everything else about it.
I'm not an engineer, but am an aviator, so while I don't know how to calculate the lift force and exact AOA numbers impact, I do know the practical impacts of all of the above! And for us simple aviators, lift=up, downforce<>up.
#639
I like those shots,....you can definitely see the wider front and rear fenders,....but the wheels are now tucked too far inside, gotta do something about that. (I'm sure they will,.....$600 spacers
If they can just ditch that abomination of a rear spoiler, then there is nothing I don't like.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
#640
Looks better and better every time I see it.
#641
If that's the standard Carrera body the Turbo and G3RS are going to be wide af.
#642
As a C2 owner, I almost feel bad for those new fenders with how much of rock magnets they’ll be. Though the stone guards do a great job of protecting, there’s still plenty of exposed area. The 991 fenders in RWD form are already quite wide. I remember when the 991 came out, a picture of a 991 C2 and 997 C4 surfaced, and the 991 hips were wider. We may see the same thing here, with the 992 C2 having as wide as or wider hips than the 991 C4.
#644
Originally Posted by Bemo
Looks are fine.
I hope the engine sounds better.
#645
