2018 991.2 spasm ride height higher than 991.1 spasm?
I can't thank you enough for taking the time to do this. I re measured and could not even fathom coming close to your results. So apparently my car does not have an option that I paid for. This is truly bizzare! Could it even be possible that they forgot to add spasm on the assembly line??
I would definitely question the apparent discrepancy with your dealer if it is indeed on the build sheet and you paid for it.
Best of luck.
Al
Plug in your VIN on the site below to verify build.
https://www.vindecoderz.com/EN/Porsche/911
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_1067_5dae3c26a7908b67229383b0e34dd43d5166064c.jpg)
I mean I've heard of Friday builds but this is on another level. Well hopefully they can just swap out parts. I'd rather have my car in for a week or two than wait two or more months for a new build. Thanks for the advice.
Took some more shots after my brother got new ps4s installed....
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_1053_a3955581ddb59356183e500be29ee85740ad69b7.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_1043_b8f74f8a63d2fe30223128fafa7ecfe148cc7d8f.jpg)
I can't imagine a 991.2 spasm being any lower than that. If so, it's got to be a couple mils at most.
OP, you got one really nicely build car. With all the performances options and no sunroof, exactly how I would done it too.
Regarding to the car's ride height, could it be because the car is so new and with the shipping block during the transit, suspension has not completely settle yet?
If this is the case, the car should drop some more after a few days with some spirited driving.
If both of our measurements are accurate, the difference is 3/8" which is very close to 10 mm which is the difference between PASM and SPASM.
Best of luck.
Al
Best of luck.
Al
Yes, 2017 DD for me. I hope to drive this car for a long time.
Nice build, very similar to mine. I think the SPASM with the sunroof delete really accentuates the lines of the 991. I hope yours is just a settling issue as has been noted. The 7M is an absolute hoot to drive.
I hope you enjoy driving yours as much as I do.
Here is a side view of mine. The gap looks similar to that of your bros.
Received 2,231 Likes
A couple of points:
1. Shipping blocks are only placed in the front suspension - at least on Porsche sports cars. On my 981, mine were left in after European delivery (for a year). I found them during the first oil change. So this is not the cause of your discrepancy.
2. The monroney sticker is not always accurate. My 2018 911 actually has two monroney's that are not identical. The first shows the painted spray nozzles listed while the second does not. This was during the elimination of spray nozzles on the 2018s and the first monroney didn't catch up in time to account for the change.
3. Doesn't SPASM come with additional suspension bits like different anti-swaybars etc? Also, doesn't it come with a slightly different lip? I forget but I think there should be some other visual queues to verify this option.
4. Mistakes are not unheard of in options from the factory. Both of my ordered Porsches were missing options at the time of delivery that were listed on the Monroney. My 981 was missing the colored wheel crest which was easily fixed by the dealer. Second was mentioned above but a new monroney was issued to correct the mistake. Incidentally, both of my missing options were added after initial order. Did you add SPASM after your initial order? Just curious.
Keep us posted. This is interesting.
Received 5,404 Likes
Strange. Hope it gets resolved.
Isn't that a PASM front lip on the car? I thought the SPASM lip was more pronounced, similar to the .1. Compare the front lip on your car to a .2 SPASM car on the web. If it's not the same, you got a PASM car.
A couple of points:
What exactly do these look like? Are they a rubber insulator placed between the spring and the body?
Edit:
I just took a look and the rears have the same white plastic spacer as first picture in this post:
https://rennlist.com/forums/991/1025...l#post14473181
Now I'm curious. I did the european delivery and wondering if there are shipping blocks on mine (991.2 C2).
Edit:
Edit:
After my second European Delivery last month, I specifically asked my dealership to verify that the spacers were removed before I drove off. The response was that spacers should never be installed on European Delivery cars (which I found odd) but they checked anyway.
Here are some pics below. My understanding is that these spacers just limit the travel of the suspension (so it will bottom out earlier to protect the front spoiler. They don't change the ride height.
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/spacer_57b5a07eaa50fc599e46ec5f27e692e191b4898c.jpg)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/150x113/spacer2_fada1d936eaeaf180bc78efce308b8c753bd39b1.jpg)
