Porsche Cup Cars
Porsche 997 RSR LCA question
Old 04-16-2017, 11:54 PM
rbahr
rbahr's Avatar
Default Porsche 997 RSR LCA question
Hi All,
The 997 RSR (later version) uses a forged AL LCA with a replaceable bearing & pin on the upright end. What I would like to understand is why the pin is available in 3 different lengths?
Thanks
Ray
Old 04-17-2017, 03:35 AM
bmwtye
bmwtye's Avatar
It is available in 3 different lengths as that allows you to fine tune the roll center of the LCA
Old 04-17-2017, 05:20 AM
Rickard 993 Turbo
Rickard 993 Turbo's Avatar
And if you dont plan to run a Rsr height and use big tires like 710 height. You Are making Your suspension worse by going the Rsr route.
People just think Rsr and wow
Old 04-17-2017, 08:21 AM
rbahr
rbahr's Avatar
Thanks bmwtye, figured as much but wanted to be certain...
Rickard - agree that using these pieces requires thought...
Ray
Old 04-17-2017, 04:14 PM
jimk04
jimk04's Avatar
Has anyone tried machining a non rsr arm out to accept the outer monoball?
arm is same casting so guess that's all Motorsport did.
tricky to clamp the arm for milling I guess .
I've removed a non rsr outer ball joint on a worn out arm...just to have a look!
Quick Reply: Porsche 997 RSR LCA question
