New Manual Shifter Design
Old 04-13-2017, 10:31 AM
  #106
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,173 Likes on 1,229 Posts
Originally Posted by Chris Lockhart
Another Hans creation that is too beautiful to hide!!! My God that's automotive art!
+1
Any of these going into a track car, cut out part of the tunnel to keep it exposed like many 911 shifter assemblies are.
Old 04-13-2017, 11:12 AM
  #107
hans14914
hans14914's Avatar
The clamp portion fits perfectly. Plenty of grip that a tie-plate is not even necessary.
I will try and get this TT bolted to a loose trans later this week and get some shifting video.
Old 04-14-2017, 11:55 AM
  #108
hans14914
hans14914's Avatar
First shifts with the production clamp. Excuse the sloppy operation - balancing a camera and loose trans while shifting with your left hand is a bit awkward.
I will try and get some better footage up, and do a comparison from stock throw to a reduced throw.
oMenRC51 (05-10-2020)
Old 04-14-2017, 11:57 AM
  #109
928NOOBIE
928NOOBIE's Avatar
Confirming here Hans we would need to pull the TT to install this one?
Old 04-14-2017, 12:55 PM
  #110
hans14914
hans14914's Avatar
I would, it makes the job much easier. Removing the front link, stock guide bearing, and foam with the TT in the car is a challenge, and I think harder than dropping the tube.
I just had a loose trans and TT in the garage, so decided to use them for the install test.
The clamp is designed so it could be installed in the car if you can weasel out the the stock foam and front link.
The foam does need to be modified by cutting out the section where the new clamp protrudes. It is much easier to do this fitting with the TT out of the car.
Old 04-19-2017, 04:30 PM
  #111
hacker-pschorr
FIRST!!!!
WOW, is this a beautiful piece...
Old 04-19-2017, 05:05 PM
  #112
AO
Supercharged
AO's Avatar
Hacker,
Let's install yours in the Coke Car Memorial Weekend and show the world how awesome it is!
Old 04-19-2017, 05:35 PM
  #113
RFJ
RFJ's Avatar
Yup got the shifter and the motor mounts ,they look so good i want to keep them on the shelf for a while.
Old 04-19-2017, 05:45 PM
  #114
hacker-pschorr
Originally Posted by AO
Hacker,
Doing 928 work in a grass field in Elkhart Lake, I limit my skills to clutches only.
Old 04-19-2017, 11:01 PM
  #115
SwayBar
SwayBar's Avatar
That was impressive, and did it in a brand new pair of jeans no less...
Old 04-20-2017, 01:17 PM
  #116
hans14914
hans14914's Avatar
I have completed some write-ups for installation. I am attaching them to this post for your reference.
Looking forward to getting some feedback.
Thanks
Hans
Old 06-15-2017, 01:55 PM
  #117
hans14914
hans14914's Avatar
I have a couple more sets of parts coming back from the anodizer tomorrow if anyone else would like to give the new setup a try. It will probably be the last batch I run for some time.
Old 06-15-2017, 04:35 PM
  #118
V33
V33's Avatar
Hi Hans,
PM sent for 2.
Thanks,
Rich
Old 06-26-2017, 01:06 PM
  #119
hans14914
hans14914's Avatar
Here are some updated photos of the parts, compliments of Haley:
Old 06-26-2017, 06:35 PM
  #120
928NOOBIE
928NOOBIE's Avatar
Hey everyone just curious...has anyone tried the install with the TT in place yet
Quick Reply: New Manual Shifter Design
