964 Forum 1989-1994
Swap Carpet Strip Trim Piece 1990 to 1991???
Old 03-28-2017, 04:17 PM
mf_rsr
mf_rsr's Avatar
Default Swap Carpet Strip Trim Piece 1990 to 1991???
Hi all - can you swap the earlier metal version of the carpet trim strip that covers the carpet to the sill alongf the bottom of the door for the later plastic version?
The metal one is fixed with 5 screws, the plastic one hidden grommets...
I need to replace mine and the later versions are so much neater I would like to use them instead so hoping it can be done!
http://type911shop.co.uk/epages/de86.../Products/5507
http://type911shop.co.uk/epages/de86.../Products/8504
http://type911shop.co.uk/epages/de86...jectID=1466109
http://type911shop.co.uk/epages/de86.../Products/5510
Old 03-28-2017, 08:52 PM
JohnK964
JohnK964's Avatar
I can't see any reason why you wouldn't be able to I would assume you'd have to drill new holes to match the trim piece. On my car MY 91 there are actually two pieces that hold the trim piece in. A piece that goes into the hole in the sill then another piece that goes in a slot int the trim piece. I have my car apart right now so if you want pictures of how they go together hit me back
JohnK964
Old 03-29-2017, 01:46 PM
justin-in-athens
justin-in-athens's Avatar
Im also interested in this mod for when I change out my carpets. Sub'd for any pictures.
Old 03-29-2017, 02:04 PM
JohnK964
JohnK964's Avatar
I will get pictures when I get home from work this after noon
JohnK964
Old 03-29-2017, 07:38 PM
JohnK964
JohnK964's Avatar
Default Pictures
This plug attaches to trim piece see top photo then is inserted into white plastic insert in car body
Old 03-29-2017, 08:01 PM
JohnK964
JohnK964's Avatar
Forgot to add there is some small adj on trim piece not sure on hole size in car body as all mine the under is still in hole
Old 03-29-2017, 09:45 PM
justin-in-athens
Thanks John!
Old 03-29-2017, 09:52 PM
JohnK964
JohnK964's Avatar
Went back out and looked there is one of my plastic inserts missing on other side of door. I used drill bits to check size of hole a letter R size bit was close R bits are .339 inch. Happy to help Justin-in-athens.
Athens Greece or Athens Georgia?
Old 03-29-2017, 09:54 PM
justin-in-athens
Definitely Georgia, you close by? Alot of Atlanta Pelicans on here. urr rennlisters...sry
Old 03-29-2017, 09:59 PM
JohnK964
JohnK964's Avatar
No I live in the Black Hills of SD I will try not to hold Georgia against you I had a insane mean ex girlfriend from Atlanta crazy and mean she was 😂😂😂.
Quick Reply: Swap Carpet Strip Trim Piece 1990 to 1991???
