Swap Carpet Strip Trim Piece 1990 to 1991???
Hi all - can you swap the earlier metal version of the carpet trim strip that covers the carpet to the sill alongf the bottom of the door for the later plastic version?
The metal one is fixed with 5 screws, the plastic one hidden grommets... I need to replace mine and the later versions are so much neater I would like to use them instead so hoping it can be done! http://type911shop.co.uk/epages/de86.../Products/5507 http://type911shop.co.uk/epages/de86.../Products/8504 http://type911shop.co.uk/epages/de86...jectID=1466109 http://type911shop.co.uk/epages/de86.../Products/5510 |
I can't see any reason why you wouldn't be able to I would assume you'd have to drill new holes to match the trim piece. On my car MY 91 there are actually two pieces that hold the trim piece in. A piece that goes into the hole in the sill then another piece that goes in a slot int the trim piece. I have my car apart right now so if you want pictures of how they go together hit me back
JohnK964 |
Im also interested in this mod for when I change out my carpets. Sub'd for any pictures.
Originally Posted by justin-in-athens
(Post 14070552)
JohnK964 |
Pictures
https://cimg6.ibsrv.net/gimg/rennlis...c0ed2b41d6.jpg
https://cimg8.ibsrv.net/gimg/rennlis...9d6ac2d78a.jpg https://cimg9.ibsrv.net/gimg/rennlis...24d1b08b88.jpgThis plug attaches to trim piece see top photo then is inserted into white plastic insert in car body |
Forgot to add there is some small adj on trim piece not sure on hole size in car body as all mine the under is still in hole
Thanks John!
Went back out and looked there is one of my plastic inserts missing on other side of door. I used drill bits to check size of hole a letter R size bit was close R bits are .339 inch. Happy to help Justin-in-athens.
Athens Greece or Athens Georgia? |
Definitely Georgia, you close by? Alot of Atlanta Pelicans on here. urr rennlisters...sry
(Post 14071794)
