I am running 19x11 et 48 on my 997.2 NB, lowered, 1.5 neg camber, outside of rim is inside of fender opening, outside of 305 tire is 1mm inside of outer fender edge.
Depends on the look you're going for, but I think that's still a bit too aggressive. Here's a photo of a 19"x11" et 42 with a 305/30 tire on a 997.1 C2S NB. The wheel you're inquiring about would be 4mm further in
The other thing you can do since all cars are a little different and might be running different alignment specs, is go to www.willtheyfit.com and enter your current setup and the setup you're looking at, and it will compare the two for you. Then with this information, knowing l what yours look like on the car, you can make an informed decision.
