19x11 ET48 fit on 997.2S?
Depends on a couple things.
1. Are you lowered. If so, how much
2. What tire size
3. Front or rear
If your running a typical tire of say 295/40/19, not lowered much, and assuming the rear...your fine.
2. What tire size
3. Front or rear
Depends on the look you're going for, but I think that's still a bit too aggressive. Here's a photo of a 19"x11" et 42 with a 305/30 tire on a 997.1 C2S NB. The wheel you're inquiring about would be 4mm further in
The other thing you can do since all cars are a little different and might be running different alignment specs, is go to www.willtheyfit.com and enter your current setup and the setup you're looking at, and it will compare the two for you. Then with this information, knowing l what yours look like on the car, you can make an informed decision.
Thanks guys! I was looking at these wheels for the car, and they come in two different setups..
http://www.mrwinterwheels.co.uk/pors...bo-silver.html
19x.8.5 ET52 for the fronts
19x11 ET64 and ET48 for the rears. I know the last ones prolly are for WB, but i really want the wheels to fill the arch i got 305 btw.
Here are the wheels on a cayman. 19x10 tough
