86 Mossgreen Metallic 5 Speed Continues
Old 02-10-2017, 07:41 PM
  #361
KenRudd
KenRudd's Avatar
Ginger motor out:
Old 02-11-2017, 06:12 PM
  #362
KenRudd
KenRudd's Avatar
Old 02-12-2017, 06:07 PM
  #363
Orantes
Orantes's Avatar
...and what a fine piece of art it is!
Originally Posted by KenRudd
And replacement ready to go in:
Old 02-13-2017, 09:40 AM
  #364
KenRudd
KenRudd's Avatar
Thank you!
Old 02-13-2017, 09:42 AM
  #365
KenRudd
KenRudd's Avatar
The intermediate clutch shaft looks good to me ( speak up if you disagree):
Old 02-13-2017, 09:44 AM
  #366
KenRudd
KenRudd's Avatar
However the friction plates appear to be end of life. When I can see scuffing on some rivets, that seems like a clear sign:
Old 02-13-2017, 09:45 AM
  #367
KenRudd
KenRudd's Avatar
Unexplained rust on drivers side coil:
Old 02-13-2017, 05:25 PM
  #368
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,507 Likes on 1,412 Posts
replace the discs they are too worn to be useful.
The stub shaft looks good,
use the Hi temp Porsche spline grease,
Roger sells it
the coil cap got water in it ,
and the water sat inside the cap,
thats what it looks like
Old 02-13-2017, 05:36 PM
  #369
KenRudd
KenRudd's Avatar
Roger sells it
Disc's are dead, on my list
Gotcha on shaft
Spline grease is also on list
Remaining question: Do you think the coil has been compromised or is the rust cosmetic only? is the old school resistance test for coils effective in this case?
Old 02-16-2017, 09:39 AM
  #370
KenRudd
KenRudd's Avatar
As a WYAIT with the motor out, I wanted to replace the "rubber/plastic donut" on the intermediate steering shaft. It was dated '85 and was showing real sign of failing. The part however is not available by itself, you have to buy the whole shaft:
The donut is easy enough to remove once you have the motor out and the steering rack dropped.
After a discussion with Roger, he provided a VW/Audi substitute. The challenge is that, while the rubber part is the same, the original has some different spacers on two of the four holes:
Some quick work using sockets as punches had the old ones removed and installed in the new donut:
Back in place and Bob's Your Uncle:
Old 02-16-2017, 09:47 AM
  #371
KenRudd
KenRudd's Avatar
I also took this time to replace the firewall foil:
This was much more of a PITA than I thought it would be. Would be easy with brake lines, fuel lines, bell housing and cooling lines out of the way, but that was not a viable option at this time, so I ha d to work around them. Ugh.
Peeling off the old was easy. Then cleaned as best I could.
Used a big sheet of this
Design Engineering DEI Reflect-A-Cool 010412 Heat Shield. Design Engineering DEI Reflect-A-Cool 010412 Heat Shield.
And cut it into manageable squares. I then pulled whatever hoses, lines etc I could away from the firewall as best I could and stuck the foil on. Not pretty, but certainly functional:
Old 02-16-2017, 09:48 AM
  #372
Chuck Schreiber
Chuck Schreiber's Avatar
Nice job!
A this the part that can cause "vague" steering??
Old 02-16-2017, 09:55 AM
  #373
KenRudd
KenRudd's Avatar
Originally Posted by Chuck Schreiber
Nice job!
Although I don't see a ton of posts about that related to the donut, I would think it certainly could, combined with the more common issues of failing rack bushings, worn tie rods, sloppy u-joints etc. Its a system where a little slop in each of those is cumulative.
It is also a 32 year old rotting rubber part on a critical system, where failure could be _interesting_. Easy/Cheap to change at this point, so certainly worth doing as cheap insurance.
Old 02-16-2017, 10:01 AM
  #374
Chuck Schreiber
Roger that, agree w you!
Keep up the great work, awesome project!!
Old 02-16-2017, 10:16 AM
  #375
JBGold07
JBGold07's Avatar
Great job and great info. Thanks for sharing in such detail!
Quick Reply: 86 Mossgreen Metallic 5 Speed Continues
