Could it be the button that opens the hatch to the blinker fluid reservoir by the other wiper...when your runny egg (bliner fluid) yolks run low, that's how you fill them back up.
Every time you press that button the arc that the wipers wipe clocks 1 degree towards the driver side. Depress it for 5 seconds and they rotate 1 degree the other way. Makes it so your can be adjusted to cover as much of your sight lines as possible.
Are you sure about that Ditto? I know a guy that pushed that button and now eats his meals through a straw.
That's not a button - it's a grease nipple. All of the grease fittings throughout the car are connected to it. Find a high-volume pneumatic grease gun, connect it to that nipple, and pump at least a pint of grease. Some may leak out around the edges; this is normal.
