Nice work, I can't wait to see the end result. I'll be repainting as well.
I noticed you are using a long Dura-Block to wetsand.
Are you using sticky back paper? If so, what brand are you using & what grit are you using?
I ask because some sticky backs don't hold up to wet sanding.
Thanks
I bought a dura block set
Reason: Add info
I cut the seals with a razor knife front was a pain glued in black colored adhesive rear window was a breeze glue looks light color and dried up between the glass and seal between the seal and car body same as front black rubbery stuff
Someone from the Mint Green Team PLEASE send John one of those "Mint" tee shirts like in post #35!! The man is ON A MISSION!! ("On a mission from God" .. Blue Brothers).
Hey John, have you seen that other thread asking about the door plugs underneath each door?
You can see inside the circle con the top picture the rusty area I found when I removed the passenger side front fender makes me sad in some ways but dam happy it is a small area should be an easy fix
I got the flu earlier this year and got lazy. Felling better now So back to working on Talia with the help of my grandson we pulled the left side front fender and also the spoiler. I found rust in the same spot on the left side as I did on the right side still not bad and should be easily fixed
Slow and steady wins the race said the tortoise to the hare. Looking good.
Thanks I have to say it is a nightmare removing the old sealant from the window channels. Nothing chemically would soften or remove the crap so scrape and sand and etching primer
