964 Forum 1989-1994
Crazy or there's a mint green coupe in there
Old 12-30-2016, 02:28 PM
  #76
JohnK964
JohnK964's Avatar
Originally Posted by the_bg
Nice work, I can't wait to see the end result. I'll be repainting as well.
I noticed you are using a long Dura-Block to wetsand.
Are you using sticky back paper? If so, what brand are you using & what grit are you using?
I ask because some sticky backs don't hold up to wet sanding.
Thanks
I bought a dura block set
Old 01-14-2017, 08:58 PM
  #77
JohnK964
JohnK964's Avatar
Default Windsheilds out
Front window rust under seal
Rust under seal right rear upper corner
Rust under seal left upper corner
Old 01-14-2017, 09:03 PM
  #78
JohnK964
JohnK964's Avatar
I cut the seals with a razor knife front was a pain glued in black colored adhesive rear window was a breeze glue looks light color and dried up between the glass and seal between the seal and car body same as front black rubbery stuff
Old 01-16-2017, 02:06 PM
  #79
R6XTERRA
R6XTERRA's Avatar
you are very determined. wow.
Old 01-16-2017, 02:51 PM
  #80
JohnK964
JohnK964's Avatar
Sanded down the a pillars only rust is in pictures already posted. Unless the is some rust hiding under the adhesive Im 😀😎👍
Old 01-16-2017, 05:09 PM
  #81
cool whip
cool whip's Avatar
Your giving me the motivation to start dealing with my 912.
Old 01-17-2017, 01:01 AM
  #82
bweSteve
bweSteve's Avatar
Received 1,050 Likes on 667 Posts
Someone from the Mint Green Team PLEASE send John one of those "Mint" tee shirts like in post #35!! The man is ON A MISSION!! ("On a mission from God" .. Blue Brothers).
Hey John, have you seen that other thread asking about the door plugs underneath each door?
https://rennlist.com/forums/964-foru...r-edition.html
They are talking about the serial #'s stamped in the rear section of each door metal. Have you checked yours (just for giggles)??
Keep up the great progress John. We all CAN'T WAIT to see it back in all it's Minty Green Jean Glory!!
=Steve
Old 01-22-2017, 08:52 PM
  #83
JohnK964
JohnK964's Avatar
Default 😩😩
You can see inside the circle con the top picture the rusty area I found when I removed the passenger side front fender makes me sad in some ways but dam happy it is a small area should be an easy fix
Old 01-23-2017, 08:26 AM
  #84
JohnK964
JohnK964's Avatar
Circled area in this pic is the area where rust was discovered
Old 03-05-2017, 07:33 PM
  #85
JohnK964
JohnK964's Avatar
Default Back on Talia
I got the flu earlier this year and got lazy. Felling better now So back to working on Talia with the help of my grandson we pulled the left side front fender and also the spoiler. I found rust in the same spot on the left side as I did on the right side still not bad and should be easily fixed
Old 03-06-2017, 12:30 AM
  #86
02m2
02m2's Avatar
John..great progress...keep the pics coming.
Old 04-24-2017, 01:02 AM
  #87
JohnK964
JohnK964's Avatar
Default I am slow
I keep chugging along getting closer to send off to body shop
Old 04-24-2017, 08:10 AM
  #88
Deserion
Deserion's Avatar
Glad to see an update, John.
Old 04-24-2017, 09:22 AM
  #89
JG 996T
JG 996T's Avatar
Slow and steady wins the race said the tortoise to the hare. Looking good.
Old 04-24-2017, 09:41 AM
  #90
JohnK964
JohnK964's Avatar
Thanks I have to say it is a nightmare removing the old sealant from the window channels. Nothing chemically would soften or remove the crap so scrape and sand and etching primer
Quick Reply: Crazy or there's a mint green coupe in there
