Old 12-13-2016, 10:14 AM
  #1381
Chris Lockhart
Chris Lockhart's Avatar
That is honestly a thing of beauty. Can't wait to see/hear the finished product.
Old 12-13-2016, 11:11 AM
  #1382
Imo000
Captain Obvious
Super User
Imo000's Avatar
Looks good.
Old 12-13-2016, 12:05 PM
  #1383
Saucy
Saucy's Avatar
wow!
Old 12-13-2016, 12:56 PM
  #1384
bw1999
bw1999's Avatar
Truly impressive
Old 12-17-2016, 10:27 PM
  #1385
ptuomov
ptuomov's Avatar
Default Signal lines
Pressure signal to the wastegate goes here:
Old 12-28-2016, 08:06 AM
  #1386
ptuomov
ptuomov's Avatar
Default Ho ho ho!
I got a new Porsche, GT3 RS, from Santa:
To add authenticity, we installed one of the axles wrong...
Wife got a model airplane:
John got fluids:
Something's still missing there from the car before it can go on the hub dyno:
Old 12-28-2016, 10:35 AM
  #1387
jwyatt8171
jwyatt8171's Avatar
Its the new traction control module he installed. Air Lock drive shaft!
Old 12-28-2016, 01:05 PM
  #1388
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,758 Likes on 1,339 Posts
Nice monoblocks on the GT3. When does this bitch run?
Old 12-28-2016, 01:56 PM
  #1389
rnixon
rnixon's Avatar
Someone is going to say it, so I will ..
You put the engine in the wrong place
Old 12-28-2016, 06:16 PM
  #1390
ptuomov
ptuomov's Avatar
Originally Posted by rnixon
Someone is going to say it, so I will .. You put the engine in the wrong place
The 928 will be fired up about the same time as the GT3 RS will be complete.
Everything is pretty much hooked on the top, more work under the car to be done. Install/fabricate wastegate line, oil scavenger line, turbo water feed lines, and a bunch of tiny wiring and then back wrap alternator belt.
Old 12-28-2016, 10:19 PM
  #1391
Rob Edwards
Archive Gatekeeper
Don't drive the GT3RS before the 928, or you'll never set foot in the 928 again.
Old 12-28-2016, 10:27 PM
  #1392
worf928
worf928's Avatar
Received 1,648 Likes on 1,075 Posts
Enough to keep the front wheels on the ground when he launches, mostly.
LOL. There is that. But, more weight in the back and some stiffer springs will be useful once the front settles.
We've got to see where it lands. The earlier system added maybe 50-75 lbs to the front, this system should probably be pretty close to that.
That's surprising. Not sayin' it ain't true. Just about half of what I would have guessed though. Turbos, tubing, heat exchangers, fluids of various viscosities, pumps, fasteners. It all adds up.
Then again, I'm about 40 lbs lighter myself compared to the previous iteration...
Your posterior is closer to the center (pick your favorite: pitch, roll, inertial yaw, etc.) of the car than all of the above bits.
Did you find the error in the instructions yet? <... evil laugh ...>
Old 12-28-2016, 10:33 PM
  #1393
ptuomov
ptuomov's Avatar
The order of gears in the paddle shifter is wrong, that's one.
Old 12-29-2016, 07:24 PM
  #1394
ptuomov
ptuomov's Avatar
Default Parallel progress
On two fronts;
Old 12-30-2016, 10:45 AM
  #1395
worf928
worf928's Avatar
Yup. That's the only confirmed error.
That kit is pretty cool from many contexts.
I have discovered that playing with Legos is harder than it was 40 years ago.
Quick Reply: Twin Turbo 928 fixed and back out there terrorizing the streets!
