LED turn signal - these ones seem really cool, anyone try it out?
I was looking at getting the clear turn signal / side lamp + smoke tint from suncoast along with some LED light replacement options when I ran into these:
http://store.ijdmtoy.com/OEM-Style-P...s-p/75-073.htm
I also see (what I assume) is the same part here on a german site: https://www.sw-tuning.de/SWLight-LED...TS::42229.html
It seems like the install is really easy and they look awesome! Anybody hear about this product before?
I noticed this:
http://www.ebay.com/itm/07-10-Porsch...WlJz1A&vxp=mtr
But for a 957, was wondering if anyone got one of these.
I have a theory on the tire well light.
I think it does 2 things, lets cars see it from the side, because it is supposed to be a turn signal light.
If you look at the lights, they have a blanked off socket for a bulb. I wonder if in other markets, this was a seperate higher wattage bulb, that is tied to the turn signal, and will flash brighter than the side marker light, but cause both the wheel well and the side to apear to flash.
If the side markers are off, it works just like a regular flasher.
If I could find a socket I would modify mine like this, and see if it triggers a code or not:
Your front module MAY be coded to have those lights be only side markers instead of actual turn signals. You would need a PIWIS, Durametric Pro (not Enthusiast) or similar tool to be able to change the coding of that module to use those lights as turn signals.
