997 GT2/GT3 Forum 2005-2012
BBS Monoblock 19" 5lug Group Buy Feeler
Old 08-16-2015, 04:20 PM
  #151
bmwtye
bmwtye's Avatar
Default BBS Monoblock 19" 5lug Group Buy Feeler
Another
Old 08-16-2015, 09:11 PM
  #152
Jamie_GT3
Jamie_GT3's Avatar
I'll have the 19x9.5 and 19x12 WB weights next week when they arrive...
Old 08-17-2015, 02:43 PM
  #153
bmwtye
bmwtye's Avatar
Wheels are individually numbered from production
#1 (with a 265 tire up front)
I chose to retain TPMS, so got these polished TPMS valve stems, as well as BBS valve caps to finish it off.
Weights are as follows:
9.0 (19.420 lbs)
9.5 (19.734 lbs)
12.0 narrow body (21.592 lbs)
12.0 wide body (22.092 lbs)
All wheels also have a knurled bead seat to prevent tire slippage.
Old 08-19-2015, 09:56 PM
  #154
BeakerGT3
BeakerGT3's Avatar
Quick question, Jamie/Tye.
On my 08 GT3, if I go with stock/OEM tire widths on these, do I need/should I run spacers if I want the same outer wheel line-up with the fenders that I have on the stockers?
I want to buy Tikore Ti lugs, and they ask on ordering if I am running spacers or not...unclear with these new wheels.
Also, do you guys have recommendations for TPM sensors that don't fail...
/Hoff
Old 08-19-2015, 10:17 PM
  #155
Jamie_GT3
Jamie_GT3's Avatar
/Hoff
Hey Hoff, The wheels are 9" and offset to be a little closer to flush than the factory wheels. You may have to play with it once the tire is on there to see how you like it. You should be able to go 10mm wider without any issues with the tires.
TPM sensors I don't have a lot of experience as I don't run them on my car. Got tired of hearing the beep on track telling me I had an issue...
Jamie
Old 08-19-2015, 11:00 PM
  #156
bmwtye
bmwtye's Avatar
For the rears I removed the factory spacer as these are lower offset than the oem wheels, which means they sit out farther. Look at the pic I posted of the rear angle, u can see it's pretty much flush.
As for tpms check out tpms.com. I've been happy with theirs
Old 09-17-2015, 10:57 PM
  #157
ammo_collector
ammo_collector's Avatar
Which MPSC2 tire size should I get for my 19x9 and 19x12?
255 / 35 ZR 19
And
325 / 30 ZR 19?
Old 12-20-2015, 06:50 PM
  #158
AgentSpeed
AgentSpeed's Avatar
Now if I can just get a set for my inbound GT4
Old 12-21-2015, 02:50 PM
  #159
Jamie_GT3
Jamie_GT3's Avatar
Could be done, need to get the GT4 guys organized. Mainly what I've heard is the BBS monoblocks are too expensive, so we haven't pursued it. Do you know what the 19" track wheel size has been decided?
Old 12-21-2015, 03:35 PM
  #160
sunnyr
sunnyr's Avatar
+1, for this or BBS FI-R that would fit GT4!
Old 12-22-2015, 03:58 AM
  #161
mooty
GT3 player par excellence
mooty's Avatar
Received 5,707 Likes on 2,342 Posts
FI-R is approx $10k
if u all can put out the money, jamie can get it done i am sure.
at 19" you want 9" front 10.5" or 11" rear.
do NOT RUN ANYTHING WIDER THAN 11", it may clear but the car will not turn.
Old 11-08-2016, 10:51 AM
  #162
Suren27
Suren27's Avatar
Anyone who's gotten these wheels - do you have any pics that you can post on a NB .1 or .2?
Thanks!
Old 11-08-2016, 12:32 PM
  #163
bmwtye
bmwtye's Avatar
Old 11-08-2016, 01:26 PM
  #164
Protocav
Protocav's Avatar
I saw these exact forged wheels at SEMA in the BBS booth. They sell standard fitments for the GT4 and GT3. I forget the exact GT4 widths and offsets, but the GT3 details that I can remember were as follows:
9 ET50
9.5 ET42
12 ET61
12 ET(Widebody, but I forget the offset)
Some may be "custom" but I think that limited fitments can be had without too much effort.
Old 11-08-2016, 03:19 PM
  #165
ilko
Agent Orange
ilko's Avatar
Speaking of BBS at SEMA, the one wheel they had in the back that caught my attention and I was most excited about was the CH-R center lock. I've had a few of those sets over the years on different cars and they are durable, look great, and won't break the bank. Perfect track wheels! Only problem is that they aren't available in 19" size, only 20"...
Here's the CH-R on my old 997TT:
Quick Reply: BBS Monoblock 19" 5lug Group Buy Feeler
