I use that DIY recently, too. I was swapping paper elements for K&N's and thought I would remove the MAF and give it a good cleaning since I was in there. I think that bad boy is coming out and getting a scrub every time I swap filters now
Ok, it was a not funny joke. And you are right. I was thinking if Rennlist was using private IP's and NAT, and the NAT table got corrupted, then theoretically internally it could show the same source IP for multiple external entries. But since NAT doesn't effect the external source or external destination then the concept wouldn't even work in theory. Therefore, I accept your poser accusation.
In fact, you're right - I AM the OP of this thread. I use a randomized TOR exit node every time I post under one of my countless bogus accounts to make it more difficult to identify that I am also Cuda, Kalashnikov, Jay, SchnellGelb, Jake Raby, AND former RL sponsor Martin....Each time I submit a reply, a burner Amazon developer account fires off CloudFormation stacks to spool up a new EC2 nano-instance, dispatch the data to the geographically randomized TOR node, and then junk the EC2 instance. In reality, the only RL members who are NOT alternate personalities of mine are you and John Ireland.
I think you are confusing me with Freak as I've never called you that. Although I have called you Snelly, which seemed logical, and in no way references former OU coach Howard Schnellenberger.
Originally Posted by 5CHN3LL
Plus I use a randomized TOR exit node every time I post under one of my countless bogus accounts to make it more difficult to identify that I am also Cuda, Kalashnikov, Jay, SchnellGelb, Jake Raby, AND former RL sponsor Martin. In fact, the only people I'm not are you and John Ireland.
