Thanks 5CHN3LL
Thanks 5CHN3LL
Just used one of your old posts to remove and clean my MAF. I'm hoping this will get rid of the
P0300, P0306, P0303 and pending P0102+P1531 codes the car just threw.
It was a great excuse to go out and buy a screwdriver set "just" for the special T20-Security Torx.
Received 1,919 Likes
Don't use Chanel #5... smells like old women.
Originally Posted by gnat
You are mistaken. He offers nothing of value and doesn't even know where his drain plug is, or so I've heard...
I use that DIY recently, too. I was swapping paper elements for K&N's and thought I would remove the MAF and give it a good cleaning since I was in there. I think that bad boy is coming out and getting a scrub every time I swap filters now
I typically post from two IPs - my static one here in San Diego and the dynamic IP currently leased to your mom's cable modem.
(I'm just kidding with him Mark. )
Ok, it was a not funny joke. And you are right. I was thinking if Rennlist was using private IP's and NAT, and the NAT table got corrupted, then theoretically internally it could show the same source IP for multiple external entries. But since NAT doesn't effect the external source or external destination then the concept wouldn't even work in theory. Therefore, I accept your poser accusation.
You can still call me Chanel #5, poser or not.
I'm magnanimous like that.
In fact, you're right - I AM the OP of this thread. I use a randomized TOR exit node every time I post under one of my countless bogus accounts to make it more difficult to identify that I am also Cuda, Kalashnikov, Jay, SchnellGelb, Jake Raby, AND former RL sponsor Martin....Each time I submit a reply, a burner Amazon developer account fires off CloudFormation stacks to spool up a new EC2 nano-instance, dispatch the data to the geographically randomized TOR node, and then junk the EC2 instance. In reality, the only RL members who are NOT alternate personalities of mine are you and John Ireland.
For reals.
For reals.
I think you are confusing me with Freak as I've never called you that. Although I have called you Snelly, which seemed logical, and in no way references former OU coach Howard Schnellenberger.
Plus I use a randomized TOR exit node every time I post under one of my countless bogus accounts to make it more difficult to identify that I am also Cuda, Kalashnikov, Jay, SchnellGelb, Jake Raby, AND former RL sponsor Martin. In fact, the only people I'm not are you and John Ireland.
