996 Turbo Forum 1999-2005
996 Turbo Brakes for sale Complete w/stock & RS29 pads too
Old 08-22-2016, 09:48 PM
911mhawk
911mhawk's Avatar
Default 996 Turbo Brakes for sale Complete w/stock & RS29 pads too
996 turbo OEM brakes, used.
Great working condition will post pics this evening (minor nicks, small paint de-lam, NOT PINK)
Front and rear calipers with OE/Textar pads installed
Front and rear rotors
Rear rotors are like new; have <1,000 miles(cross-drilled Sebro)
Spring clips and caliper bolts for all 4 corners
Additional new OE/Textar rear pads IN BOX
BRAND NEW Pagid RS29 pads front and rear IN BOX
993 install post:
https://rennlist.com/forums/993-foru...ny-issues.html
$2,000 by PayPal.
I will ship to CONUS
Buyer pays ship & PayPal fees.
Old 08-24-2016, 03:16 PM
T10Chris
T10Chris's Avatar
Spare set or did you make an upgrade?
Old 08-24-2016, 04:37 PM
911mhawk
911mhawk's Avatar
Did GT-3 350mm, this spring.
Big improvement over stock, especially at higher speeds.
Old 08-24-2016, 05:37 PM
Third-Reef
Third-Reef's Avatar
People say no need to upgrade, but 350mm and 6 pot calipers make a big difference at the track.
Old 09-05-2016, 03:15 AM
911mhawk
911mhawk's Avatar
$500 for the NIB RS29 pads front &. Rear
Old 09-05-2016, 12:33 PM
SteveMFr
SteveMFr's Avatar
Actually, with goods pads and fluid, you can go quite far with stock brakes - even on track. But just as an aside: is this pic a 996tt? Is that Rotor mounted on the correct side?
Old 09-05-2016, 01:04 PM
Third-Reef
Third-Reef's Avatar
Yes, those are on a 996. They certainly look like they are swapped. I went out and checked ( I was ashamed I had never noticed it) and the vents run opposite the way the drilled holes look like they run, so they are on correctly. I had Pagid yellow pads on my 99 C4 with fresh fluid (ate blue?) and while they worked well (always stopped on a dime), the feel and pedal position would change during track sessions.
Quick Reply: 996 Turbo Brakes for sale Complete w/stock & RS29 pads too
