Refresh951 - Latest 3L Build
07-02-2016 | 11:28 PM
Quote:
Originally Posted by
URG8RB8
Looks Great Shawn, ETA for first start?
Thanks, i think 2-3 weeks if all goes well.
333pg333
Super clean as always Shawn. What gasket is that? How did you work out the headers?
Thanks, Cometic.
E-man930
Did you block fill this one?
No, block was already sleeved when I got it so we did not fill it.
blitz951
Great work as usual.
What are you using for an oil cooler/radiator? Stock?
Thanks, My neighbor just bought a bigger radiator and 3x oil cooler from LR.
07-02-2016 | 11:33 PM
Some bling
07-03-2016 | 01:03 AM
Wow, they turned out really nice!
The gasket looks copper?
How did you do the headers?
07-03-2016 | 05:34 PM
I have one of those radiator/oil cooler combo's and its not working well.
Car runs hot when its warm out and to the 3rd line on the temp gauge with ac on. Not sure if others have had this problem but wish I had kept the stock set up at this point.
Anyway, looking forward to your finished project.
07-06-2016 | 09:38 PM
333pg333
Cometic with copper spray.
Stock headers with modified crossover.
07-06-2016 | 09:41 PM
Still waiting on a few small bits from Porsche but basically complete
07-06-2016 | 09:50 PM
NICE
07-06-2016 | 10:05 PM
AddictLifetime Rennlist Member
07-06-2016 | 10:11 PM
Very nice engine. Why do you use copper spray isnt cometic strightly for dry instalation?
07-06-2016 | 10:49 PM
refresh951
Thanks. Looks factory!
07-07-2016 | 02:44 PM
Looking forward to hearing results after install.
08-16-2016 | 11:16 PM
08-17-2016 | 09:07 AM
Will you try to control the Variocam with a PWM input instead of the factory on/off input?
08-17-2016 | 10:01 AM
Thom
Do you think doing so would allow "stepped" Variocam?
As in...different levels of advance vs on/off?
That would be cool.
08-17-2016 | 10:53 AM
It depends on how other components such as cams, intake, headers, etc balance each other. It makes sense to me that shorter than stock 968 length runners may work better with a switch point higher than 5500 rpm, all other components being stock.
