Carpet Question - What are these pieces
I've been stripping my interior carpet in preparation for installation of a new carpet set ---- I laid everything out and it makes sense --- however I have two pieces that I'm not sure what they are --- anyone have any ideas?
Thanks
Thanks
Ah, I think maybe here is a possible answer ---
https://rennlist.com/forums/964-foru...r-install.html
I take that back ... I already have the piece that goes over the center console .... With a seam where there should be a seam going from the upper piece to the lower piece. Still baffled at what the other piece is...
Might be an extra piece for a cab install. It would go behind the rear seat pocket for the top.
I need that piece if you don't use it. Mine has a black mark that won't come off.
BTW are you sure you want my piece? My new carpet is not classic grey. It is a slightly warmer grey sikverknit. PSL-10 color code. Comparison between PSL-10 and CG is in the 2nd pic.
Yes, a lot of Elbow grease for a subtle change .... OCD.
I think my conclusion in #5 is wrong ....
I think my conclusion in post #5 is wrong because C23, which is the carpet that goes over P2 and P3 combined, has a different seam than "M2 or M23".
P = original plastic piece
C = original carpet
M = new carpet
P3 originally sat on top of P2 and was covered in one shot by C23.
C = original carpet
M = new carpet
