86 Mossgreen Metallic 5 Speed Continues
Old 05-07-2016, 11:21 AM
  #316
KenRudd
KenRudd's Avatar
New Cam Shaft seals
Old 05-07-2016, 11:22 AM
  #317
KenRudd
KenRudd's Avatar
Beginning front re-assembly
Old 05-12-2016, 03:21 PM
  #318
KenRudd
KenRudd's Avatar
Porkensioner
Old 05-12-2016, 09:16 PM
  #319
KenRudd
KenRudd's Avatar
Not sure which I like more, Porkensioner or 32vR+Bumpstick
Old 05-12-2016, 11:17 PM
  #320
PorKen
Inventor
PorKen's Avatar
I like the tape idea. It is difficult to keep everything together at times.
If I may, a couple of observations:
1. It may be just superstition but it has been said that the timing belt text should be readable from the front.
2. Cam timing cannot be set accurately on the stand, IMO. The engine needs to be turned over with the starter to settle the belt.
3. Timing with a new belt should be 0° on the 1-4 side as a new belt will retard about 2° after about 1K miles.
Old 05-13-2016, 09:39 AM
  #321
KenRudd
KenRudd's Avatar
Porken-
Curse you, you are in my head again!
Understood, but I had everything off and wanted to get it back together fairly close ( i.e. less than a whole tooth off ). It is easy to tweak later, when motor is in place and I can spin with starter. If I have to pull the belt while in place to shift the belt over a tooth , that makes it a much bigger PITA.
To confirm/clarify, the instructions say Right/Passenger/1-4 should be 1-2 degrees retard to compensate for engine expansion when warm. You are indicating that measurement would be for a "used" belt. A new belt should be set to zero 0, and rechecked at about ~1k miles. What about Left/Drivers/5-8? Start at recommend 0 still, or should it be advanced a bit to allow for stretch?
Old 05-14-2016, 04:43 PM
  #322
KenRudd
KenRudd's Avatar
Old 05-14-2016, 06:09 PM
  #323
KenRudd
KenRudd's Avatar
Progress
Old 05-15-2016, 12:58 PM
  #324
KenRudd
KenRudd's Avatar
Minor detour from motor work. Tie rods were showing slop, so dropped in a fresh pair.
Old 05-20-2016, 10:18 PM
  #325
KenRudd
KenRudd's Avatar
It may never be seen again and there won't be any performance gains, but the throttle plate sure shines up nice!
Old 05-21-2016, 08:55 PM
  #326
KenRudd
KenRudd's Avatar
Cleaned, fresh O-Rings, etc.
Old 05-22-2016, 12:01 PM
  #327
KenRudd
KenRudd's Avatar
No real reason.
Old 08-23-2016, 10:22 AM
  #328
KenRudd
KenRudd's Avatar
Rear Bearings awaiting install.
Old 08-24-2016, 10:18 PM
  #329
KenRudd
KenRudd's Avatar
Sloppy
Old 08-28-2016, 08:50 AM
  #330
KenRudd
KenRudd's Avatar
Progress on the rear wheel bearings replacement
Quick Reply: 86 Mossgreen Metallic 5 Speed Continues
