I purchased this:
Torque Solution Urethane Insert Transmission Mount
Applications: Porsche 996TT/GT2/GT3/C2 & GT3 Cup 997TT/GT2/GT3 & RS/C2/C4 and GT3 Cup
**Fits Manual & Automatic Tiptronic Transmission. Will not fit the PDK transmission.
It clearly states 996 C2 Manual Transmission. 1998-2011
The bracket is the transmission mount itself. The insert is the plastic part. I just changed mine on the GT3 a couple weeks ago. It sits right in front of the transmission box in the center of the car.
I think that's the later type transmission mount , you might have the earlier type which was two pressed steel brackets , one is a plate with four bolt which bolts to the body and the other is like a cross brace that fits into it and bolts to the rubber mount on the end of the box.
The support you show is for the GT3 which is a different transmission. I don't know if it used in any other models but definitely not in a Mk1 or Mk2 C2 or C4.
If you have a C2/C4 996 you can use the Function First inserts to firm up a sagging transmission mount or even to make it firmer than standard. The other option is to punch/cut/mangle the old mount out of the transmission and press in a new mount.
Mk1 six speed manual. The big hole at the lower left is where the mount gets pressed in.
Reason: Added photo of manual transmission
If you can't return that 996tt trans mount, let me know. I am replacing my engine mounts this week and may need a trans mount if my current one is shot.
Let me know if you need it.
You can have it for $350.00 and I will cover PP fees and pay for Priority Mail shipping to you.
There is mis-information abound regarding the transmission mount styles used on the different models. Here is a breakdown for the 2 styles of transmission bushings:
The singular transmission mount bushing that's pressed into the trans bell housing is used on:
996.1 Carrera (manual)
996.1 Carrera (tiptronic)
996.2 Carrera (manual)
The transmission mount carrier that uses 2 bushings and can be entirely removed from the car is used on:
996.2 Carrera (tiptronic)
996 Turbo
996 GT2
996 GT3
Comprehensive Shifting Solutions for your Porsche.
