997 GT2/GT3 Forum 2005-2012
Mounting rear remote reservoirs?
Old 04-24-2016, 09:22 AM
Dan GSR
Dan GSR's Avatar
Default Mounting rear remote reservoirs?
Where do you guys mount the rear reservoirs on coilovers? If you mount inside the cabin, where did you drill the hole? Pic are appreciated
Old 04-26-2016, 09:36 PM
bmwtye
bmwtye's Avatar
Do you have quick disconnects on the lines? There are several areas you can mount them to:
1. The Roll Bar if equipped with one
2. Under the rear deck carpet on the aluminum panels that hold the wiring harness and ECU
3. On Each side of the tranny tunnel
Old 04-26-2016, 10:09 PM
Dan GSR
Dan GSR's Avatar
I do have the quick disconnects. Where do you route the kine thru?
Old 04-26-2016, 10:27 PM
bmwtye
bmwtye's Avatar
You will need to drill a small hole for the line, and then use a rubber grommet to seal it and prevent chaffing the hoses. For further protection of the hoses, use 7/16" ID fuel line and cut it open lengthwise with a razor and then slip the fuel line over the canister hoses and secure with zip ties.
Quick Reply: Mounting rear remote reservoirs?
