Do you have quick disconnects on the lines? There are several areas you can mount them to:
1. The Roll Bar if equipped with one
2. Under the rear deck carpet on the aluminum panels that hold the wiring harness and ECU
3. On Each side of the tranny tunnel
You will need to drill a small hole for the line, and then use a rubber grommet to seal it and prevent chaffing the hoses. For further protection of the hoses, use 7/16" ID fuel line and cut it open lengthwise with a razor and then slip the fuel line over the canister hoses and secure with zip ties.
