Tech: The 944 / 951 Ignition System.
Old 10-10-2014, 02:32 PM
  #166
Cauf61
Cruisin'
Cauf61's Avatar
The first test whent fine.
On the picture you see the ignition signal divided in to two signals for the two coils.
It's the position of the rotor thats send the signal ( and spark ) to cyl 1 and 4 or 2 and 3.
The timing is not altered and produced by the marelli ECU.
Old 10-10-2014, 02:33 PM
  #167
Cauf61
Cruisin'
Cauf61's Avatar
Both ready for action. :-)
Old 05-08-2015, 08:24 PM
  #168
Jay Wellwood
Jay Wellwood's Avatar
Originally Posted by refresh951
May want to carefully check your plug wires (both ends), I had an issue with misfire a while back and it was a plug wire. Also, check prices at Summit for Blaster Coil, may be a bit cheaper. If you use an HVC II coil, you will need to a capacitor to the DME to kill some harmonics. I will try to dig up the details if anyone needs them.
Any details that you can now recall? I assume this will be applicable to the M-Tune?
Nearing completion of the 3L turbo project - would like to nail down the details of this setup.
Parts as I have noted include: Coil, M-Tune, modified DME and a special coil wire from Magnecore. Using the adjustable FPR.
What else is needed?
Old 07-14-2015, 12:07 PM
  #169
bebbetufs
bebbetufs's Avatar
Will adjusting the dwell time in the M-tune eliminate the need for the 0.8 Ohm ballast resistor required if running the MSD blaster coil?
Old 07-15-2015, 05:20 PM
  #170
Humboldtgrin
Humboldtgrin's Avatar
Have any of you seen the "high plasma ignition systems" out there? I bought a unit from Blue Phoenix ignitions. It has full race mode which will make your plugs turn into a welder. It's awesome!!! The plugs last one race on high mode and you have to use copper core plugs, But there are three setting on mine. Off(stock) (on-low, plugs last 5kmiles) (on-high plugs last one race). Look it up on YouTube. Blue Phoenix plasma. And I'm using water injection on top of that with an intercooler sprayer. Have not set it up yet, just getting the parts together!
Old 07-15-2015, 07:09 PM
  #171
Xaerran
Xaerran's Avatar
Last I talked with Josh, the answer was yes. I am running the MSD blaster coil with M-tune and no resistor. No problems.
Old 07-19-2015, 04:39 PM
  #172
bebbetufs
bebbetufs's Avatar
Sounds good. Thank you.
Old 03-19-2016, 01:33 AM
  #173
Black51
Black51's Avatar
Bringing this thread back. Great read btw.
I'm just finishing up a build, and running the HVC II coil. I'm running Rogue hardware. My question is does anyone have a dwell map for this coil, or can someone help me changing the values in the dwell table? Any help would be greatly appreciated!
Old 03-19-2016, 04:23 PM
  #174
URG8RB8
URG8RB8's Avatar
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
Yes, I have it and can send it to you. PM me your email address.
  #175
URG8RB8
URG8RB8's Avatar
If your DME has not been modified to accommodate this coil you will blow it up.
Old 03-19-2016, 04:49 PM
  #176
Black51
Black51's Avatar
PM'ed.
Old 04-26-2016, 03:39 PM
  #177
darek_u
darek_u's Avatar
Does this table look like stock coil dwell times or I'm looking at wrong place in bin file?
Old 04-26-2016, 04:01 PM
  #178
odonnell
odonnell's Avatar
What's the X axis? I doubt that table is dwell, since the normal dwell time for a coil is between 2-10 ms.
Here's what the math says for dwell on a dizzy setup, which is basically the same results as Rogue's study when it comes to max possible recharge time for the coil. This accounts for discharge time as well for a typical inductive coil.
and here's what I calculate for a WS setup, note how even at high RPMs you still have enough time to fully saturate the coil (achieve max usable dwell).
Old 04-26-2016, 04:07 PM
  #179
darek_u
darek_u's Avatar
X axis is battery voltage versus Y RPM. In fact it looks pretty much like a dwell table but I'm not an expert here
Old 04-26-2016, 04:11 PM
  #180
odonnell
odonnell's Avatar
Ah. In that case, it very well could be. I was thinking maybe X axis was a running condition like load, but that makes sense.
Quick Reply: Tech: The 944 / 951 Ignition System.
