$500 problem with clear turn signals and silver hood emblem
Originally Posted by P-daddy
I recently refinished a set of fogs. New Hella glass lenses were ordered from eBay seller in Germany mentioned in post above.
And if You always liked Audi RS2 withot knowing why, I can tell You it's because they have 993 front foglights and turn signals!
And re the fog lights, the "glass" is real glass so them looking tatty is often due to the inside beeing dusty and sunyellowed!
There is a thread somewhere here about how to fix them and paint them silver inside!
The Hella glass replacement lenses I purchased were made in Germany. Fit and finish were perfect. The old lenses were not easy to remove. I heated the entire assembly in the oven at ~130 deg for 15-20 minutes to soften the caulk/adhesive. I then used a slim profile razor to cut at an angle around the periphery where glass meets plastic. A lot of patience is needed here. Prying will damage or crack the plastic housing. The glass will eventually lift off. Clean residual caulk. Prep inner housing, primer and apply several thin coats of high temp silver paint. Installed new lenses with 3m grey sealant/adhesive. This is the only pic I could find.
