Chassis System Failure & Garage Memory
Like everyone else I have been living through this warning thinking it was the -40 weather. Still having the issue even with the recent warm-up. Took the car to Service Center and they are at a loss. The following are the notes:
Scanned vehicle systems for trouble codes, retrieved 644/284 control position not adjustable vehicle too high or low, 530/212 shock absorber LR on time exceed, shock absorber LF on time exceeded. Inspected level sensors, all appear good. Cleared trouble codes both shock absorber codes remained off (so no current codes), control position comes back immediately. With all of this, also unable to manually adjust the vehicle ride height and the light 1 level "lower" on the ride height is lit up as opposed to the middle light position.
Now pulling out of the garage everything was fine using the memory to close the garage. Returning home suddenly it is not working. Is this independent of the above or is there something electrical going on?
Thoughts? Thanks in advance for everyone's time and response!
Received 1,160 Likes
Hi WIsconsin,
I'm not certain where you meant to post this - but probably not in the test and forum glitches subforum. Perhaps if you told us what vehicle this is on we could help by moving it to the correct location..
