Where to buy parking light Bulb in Markham
One of my parking light bulb burned out and I don't feel like driving to the dealer for one so does anyone know what store I can just walk in and get a Philips 12961 BV bulb ? Thanks
Porsche part #: 99963103390
Canadian tire? I got my DTRL there. No listing on the guide book. Take the bulb in and compare.
Buy 2, the other side will go next, or the colour between the two will bug you.
you can use a 194 bulb as a replacement. Canadian Tire will stock these. I would suggest changing both as the wattage on 194 is slightly different than OEM bulb.
I use 194 bulb in my 2007 a few years ago. All is good
sorry, to clarify you can use 194 which is ~3.8W. 194 is available in amber (194NA) if you have clear/smoked side marker. If you are looking for clear bulb, then 168 is a close match in terms of wattage (4.9W). Stock bulb is listed as 5W.
I also just went to Canadian Tire. If you want LED's you can goto Station 28 at Pacific Mall.
