$700 for SS brake lines with install?
Called a local tuning shop for a set of SS brake lines with install. The rep said it will take 4 hours to do it and that'll be $700. They quoted $260 for the part which is reasonable but you can do a lot in 4 hours.
The price is a little high... not unreasonable, but ya, you should be able to find somebody to do it cheaper.
Honestly, don't waste your money. It's the fresh fluid that makes a difference. The pseudo-science behind SS brake lines just doesn't result in any difference besides bragging.
Buy Castrol SRF, and flush it every year if you want to spend money on an upgrade. Castrol SRF and Porsche brakes is more stopping power then you need. A good Dot 4 fluid is probably more than adequate.
Spend the money on lapping or track time instead...
Captain Obvious
Super User
Super User
I'd charge 2.5hrs for the install and "flush" so 175$ plus a can of brake fluid either ATE SL or Type 200 is around 23$ plus the lines.
I even consider the rubber ones wear items.. I'd say life on them is about 7-10 years depending on driving. The "stress" areas are just before the crimped fittings that seem to crack. I've refused to sign tech inspections because of old brake lines.
