Exhaust/muffler repair in GTA
Old 08-20-2015 | 09:13 PM
Biscuits704's Avatar
Biscuits704
Default Exhaust/muffler repair in GTA
Any recommendations, gents?
I don't think I need to replace anything at this point (at least I hope not), just a bit of welding on a couple of splits/small holes.
Thanks in advance!
Old 08-20-2015 | 11:26 PM
blotto649's Avatar
blotto649
I just had some work done at Thruway Muffler, 475 King East in Toronto - the place ain't much to look at, but good work, quickly, and very fairly priced.
Old 08-21-2015 | 01:04 AM
Pags993's Avatar
Pags993
I've used Hot Rod Scott's in the west end a few times with great results each time.
Old 08-21-2015 | 03:12 PM
Zookie's Avatar
Zookie
you can try Eurocharged in North York or Maxus Fabrication in Brampton
Old 08-21-2015 | 10:49 PM
Biscuits704
Thanks everyone - I'll make some calls.
I did try Thruway earlier... no dice. Was told they "don't deal with high-end cars". My explanation that my 951 has a pretty regular exhaust and I'm just looking for a bit of welding rather than an engine rebuild fell on deaf ears!
Old 08-21-2015 | 10:56 PM
Turbodan's Avatar
Turbodan
hopefully it is not the exhaust manifold (common issue on 951's), as it is a big job to re and re. good luck!
Old 08-22-2015 | 12:44 AM
Dinicod's Avatar
Dinicod
Tech Tune Exhaust in Etobicoke.
Old 08-22-2015 | 12:57 PM
Biscuits704
Thanks everyone for the input. I ended up going to Quick Muffler on Dufferin. $60 later, fixed up, job done.
I was offered a cat replacement, straight-through system with stainless Magnaflow muffler for $800. Came close to pulling the trigger but I had to leave and more research was required anyway.
I tried Tech Tune after reading some very positive things; however when I left them a vm on Wednesday they didn't return it, and when I got a hold of them yesterday I found out they're not open Saturdays.
