Noise limit at LCMT
Old 12-01-2014 | 08:26 PM
Dino524's Avatar
Dino524
Default Noise limit at LCMT
Hello to all,
I've recently traded my Cayman S for a 2007 GT3. The new car has a sharkwerks bypass and sounds absolutely fantastic. The original muffler did not come with the car and my concern is passing the noise test at LCMT.
I have been attending DE events for the past two years at LCMT and am aware of the 92db sound restriction. My question is will I pass the sound test if I don't use the "sport" setting as the engine sounds much more quiet?
I also saw in some older posts the possibility of further"quieting" the exhaust by capping a vacuum hose keeping the lower exhaust flap closed at all times.
Would appreciate your thoughts on this issue..
Old 12-02-2014 | 12:53 AM
wildcat077's Avatar
wildcat077
I think Bob Rouleau might chime in on this one,if anybody knows the sound rules, he's the one that would be able to answer your question !
One thing for sure is that the 997 GT3's are pretty much borderline ,even with stock exausts ...
Cheers
Phil
Old 12-02-2014 | 01:28 PM
Dwane's Avatar
Dwane
At the beginning of this season, guys were having trouble with sound, with the same setup they ran in 2013.
Old 12-02-2014 | 02:18 PM
Bob Rouleau's Avatar
Bob Rouleau
Still plays with cars.
I'd be worried with the bypass. The Sport setting only makes it quieter at low revs once you get over 4000 RPM the valves open anyway and you get full sound. Since LCMT measure not only on the front straight but at random locations around the track - especially where cars at a max power, I'd be concerned.
Old 12-02-2014 | 03:42 PM
Dino524's Avatar
Dino524
This is what I was afraid of... What have others done in a situation similar to mine? Thinking of trying the solution offered on the Sharkwerks website, whereby they suggest plugging somekind of vacuum hose which would keep the lower exhaust flap closed all the time - regardless of rpm. Apparently, this reduces exhaust noise significantly and meet the db limit at Laguna Seca (limit of 92db).
Any other suggestions? deflector tip? Short shifting at 4000rpm is not an option!!
Old 12-02-2014 | 03:46 PM
Bob Rouleau
The vacuum hose trick probably works. Easy to reverse too apparently. I did the reverse on my 996GT3 -always open but returned it to stock because it had too much drone on the road.
Old 12-02-2014 | 07:36 PM
Dino524's Avatar
Dino524
Thanks Bob. I'll look into this over the winter. Plenty of time to figure something out...
Old 12-03-2014 | 10:19 AM
Paseb's Avatar
Paseb
You can try a down pipe, this served me well in the past
Old 12-03-2014 | 02:29 PM
NVRANUF's Avatar
NVRANUF
Leave it open and you will DEFINITELY get black flagged!! (unless you lift slightly when passing the sound monitor guy, usually parked on the inside beginning of corner 6)
First hand info here.... I mean offender!!
Bottom line, just plug the actuator solenoid and you won't have any noise issues at LCMT.
Simple solution that's easy to do.... and undo... and you will remain on friendly terms with the LCMT sound police!
Old 12-03-2014 | 03:05 PM
Crazy Canuck's Avatar
Crazy Canuck
My 996 GT3 has a stock exhaust and I was told by the sound guy I was just under the limit. This was a day featuring low hanging clouds which makes things worse but even so, it's stock!
Old 12-03-2014 | 04:31 PM
Dino524's Avatar
Dino524
Thanks Guys, glad to see there are options for me. I only thought about the noise restriction issue after I bought the car...
Peter: when you say to "plug the solenoid actuator", assume you mean the simple mod proposed on the Sharkwerks website (ie. plug the vacuum tube). If so, the solution sounds ridiculously easy!
Old 12-03-2014 | 04:49 PM
NVRANUF's Avatar
NVRANUF
Just follow the link below:
Link
Old 12-04-2014 | 07:22 PM
Dino524's Avatar
Dino524
Thanks Peter. One last question: where is this actuator solenoid (or vacuum hose as they call it)? Is it reachable from the trunk or underneath the car? Can't really tell from the pictures provided as it's a closeup picture.
Old 12-04-2014 | 09:45 PM
Bob Rouleau
Dino the vacuum lines are visible when you open the engine lid. Should be trivial to make the change. Open your lid and look
Old 12-05-2014 | 11:58 AM
Dino524's Avatar
Dino524
Thanks for the help Bob. Looking forward to next spring!
Quick Reply: Noise limit at LCMT
