Gundo hack GTA ?
Old Mar 3, 2014 | 09:09 PM
  #46
aviography's Avatar
aviography
Originally Posted by wucash
I think thats the fister not the gundo hack. Gundo connects the 2 side pipes.
I have the fister one.. I think the way to go is Both... Fister is awesome, but if you have the mufflers out might as well do both.
Wait a minute, you now say you have the Fister version yourself yet you mistakenly identified the other one is the Fister version in your earlier post today? I have NEVER seen anyone make that mistake.
Dinicod, you don't need to do both, either one should be fine by itself, unless you just want to spend more money for little additional return. The Gundo hack is to imitate the factory PSE but fully open at all times, Fister will give you similar sound without touching the cans, it's a little lighter because less tubing is required as compared to the Gundo hack, but it takes more skill to do it just right with the tight space to work with.
Old Mar 3, 2014 | 09:49 PM
  #47
kgoertz's Avatar
kgoertz
After a bunch of research my conclusions were:
- the Gundo hack is essentially the same as the factory PSE but without the solenoid to control it
- for the 3.4L muffler the Gundo hack isn't very effective
- for the 3.6L muffler the Gundo hack has a ~medium increase in volume
- for either the 3.4L or 3.6L the Fister hack has a medium increase in volume depending on the size of the bypass pipe (ie 1.5", 1.75", or 2" pipe)
- Some people have combined both and the conclusion seemed to be that it was slightly louder than either hack individually and still tolerable.
Please correct me if my conclusions were wrong.
In my case I had already replaced my original cats with a 200 cell X-pipe from Maxspeed Motorsports which already had increased the volume and improved the sound a little. I didn't want to go overboard so I stuck with the Gundo hack.
Old Mar 3, 2014 | 10:21 PM
  #48
996_North's Avatar
996_North
If you are looking for a growl under 4K RPM, Gundo is not enough IMO on 3.4. If you want the pow factor at higher RPMs it is very nice, but this is all a matter of taste and subjective.
Old Mar 3, 2014 | 10:32 PM
  #49
wucash's Avatar
wucash
I said I think not I know that I have gundo hack. Now that someone updated my knowledge I know that I have fister hack .
Old Mar 20, 2014 | 03:14 PM
  #50
9964runner's Avatar
9964runner
Finally got around to pulling the mufflers so I can install new plugs.
So off I went mufflers in hand to have the 2nd hack added, turns out because of the way Pfaff modified the mufflers originally nothing more can be done with them. As happy as I am with them, I would really like a little more, however I need to start with an un-modded muffler,
So....... if anyone is looking for a set of Pfaff tuning mufflers I willing to trade even.
Old Mar 20, 2014 | 10:12 PM
  #51
Revn29k00's Avatar
Revn29k00
I can vouch for the sound of the Pfaff mufflers. Its a great sound. I've got 997 headers as well so I'm not sure how much different mine would sound than yours.
I've never really closely looked at how they modified them but what have they done so that you cannot modify anymore?
Old Mar 20, 2014 | 11:23 PM
  #52
9964runner's Avatar
9964runner
Revn, whats your thoughts on the 997 headers?
pfaff uses a "J" bent pipe between inlet and outlet pipes not leaving room to add the PSE hack. Pipe diameter is also on the smaller side, but the way its rigged you can't just swap it for a larger one.
Car is sitting at our old house, I'll get a few pics next time I there.
Old Mar 21, 2014 | 10:41 AM
  #53
Revn29k00's Avatar
Revn29k00
I purchased the car with this set up so quite honestly I can't comment on the difference they made. It would be interesting to hear the two side x side
Old Mar 21, 2014 | 11:11 AM
  #54
aviography's Avatar
aviography
Mike,
I have the Fister D, we can do the side by side comparison next time, and both be charged with "making unnecessary noise" under HTA!
Old Mar 21, 2014 | 01:08 PM
  #55
Torontoworker's Avatar
Torontoworker
Mike,
Do you know anyone who has done both these mod's? I'd be interested to know what the sound is like. I've got to decide in the next few weeks which one I'm going to do or maybe both?
Old Mar 21, 2014 | 01:18 PM
  #56
aviography's Avatar
aviography
I don't, but I would not think anyone needs more than the Fister D mod, keep in mind my car is a Cab, so I can hear the exhaust more so than a Coupe, even with the top raised.
It is quite loud outside of the car already even for the 3.4L mufflers, IMHO adding the Gundo hack would not likely see the ROI in cost vs increased sound, plus you are now more likely to **** the one picky neighbor off for him/her to call the cops.
Old Mar 21, 2014 | 02:04 PM
  #57
Torontoworker
I don't know. I find my car too quiet right now and I've heard the Fister D mod and it isn't that loud. Maybe I've lost hearing after 27 years at the track?
There is a 964 down the street from me that is way louder then these hacks plus all the Harley's - some with those fat bob pipes. I don't think combining both mod's would be close to those guys. Besides, I don't think mild acceleration would cause any miscarriages or Def Con 1 alerts.
Here's the one I'm talking about:
https://rennlist.com/forums/attachme...mod-to-pse.jpg
Old Mar 21, 2014 | 10:50 PM
  #58
Dinicod's Avatar
Dinicod
Just finished installing my Fister D modded cans today and all I can say is WOW! Sounds fantastic. Worth every penny and just right! Kudos to Steve at Tech Tune for the work.
Old Mar 21, 2014 | 11:04 PM
  #59
aviography's Avatar
aviography
Did you take any pics of them before installation?
Old Mar 21, 2014 | 11:59 PM
  #60
Dinicod's Avatar
Dinicod
No, sorry man. Not much to see to be honest. Tech put a coat of flat black paint on the pipe/weld points for rust protection I guess. Welds look ok I guess, but again coat of paint on them. Happy with the result though.
