FS 2008 Trailex CT-7541EB
2008 Trailex CT-7541EB (electric brakes) trailer
It has the factory winch, factory aluminum toolbox, factory ramps, spare tire (tire needs to be changed), 2 aluminum gas canister holders (one needs to be rewelded- just the side of the box and not on the trailer side), 2 gas canisters and the factory tire rack.
I also have the orignal manual & receipt to prove the model/year.
3rd owner as the previous 2 owners were in the local PCA.
I only used the trailer for a 3400 km trip. During the trip one of the rear tires got badly worn. The rear axle (right side) has tire cupping and the front axle (left side) has inner wheel wear. See my lower post for more details on the uneven tire wear issue. There is a link with pictures describing what each wear is caused by.
Other than the uneven tire issue and approx 3 worn tires, the frame is in good condition.
It might be a combination of a bad axle, axles that need to be realigned, wheels balanced, etc.
I intended on keeping this for a long time even if I wouldn't use it for a while since they don't rust, don't depreciate and most importantly they are hard to find used! My original intention was to use it when I would start tracking my car but unfortunately it will not happen since I plan on selling the vehicle. There is no sense in keeping it when it can be put to better use by someone else.
If it wasn't such a hassle and if I had the time I would go have it inspected.
Price- taking offers for now so please PM me.
Located in Long Sault, Ontario. Approx 1 to 1.5 hours from Ottawa and 1 to 1.5 hours from Montreal. Let me know if anyone wants to come inspect it.
![](http://i1331.photobucket.com/albums/w582/wabbit636/IMG_0016_zps5201a0cf.jpg)
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
![](http://i1331.photobucket.com/albums/w582/wabbit636/IMG_0015_zps4b91b78f.jpg)
[IMG]
![](http://i1331.photobucket.com/albums/w582/wabbit636/IMG_0011_zpsddf164ba.jpg)
Last edited by wabbit636; 07-07-2013 at 01:23 PM. Reason: added pictures & added more on the tire wear issue
As for the wear. I did some research this morning and now have a better idea:
The front axle (left side) has "one side wear" which is said to be a wheel alignment issue.
On rear axle (right side) the tire wear is "cupping". This means that it has something to do with suspension parts (wheel bearings, bushings, springs, etc.). It says in the link below that worn components need to be adjusted or replaced.
Now with this info it might not need a new axle. I don't know which suspension parts need to be replaced or adjusted. Suspension parts are cheaper than an axle though and this can be easily fixed.
Once fixed this is a great trailer. It only weights 950 lbs and easily loads lowered cars due to the height of the trailer and the long ramps.
I knew both previous owners as they were in the regional Porsche Club. The 1st one did a lot of tracking in different states so he would have put a lot of mileage on the suspension.
See this link. It has a chart showing pictures of trailer tire wear and what they mean:
Look at the one side wear and the cupping sections to see the issue on the trailer:
http://www.google.ca/url?sa=t&rct=j&...48705608,d.bGE
