Where could I get a tamper proof Triangle screw driver?
Doesn't seem very common and it need to be a very thin. I'd drill out the center pin but its to hard to get at and a very small diameter.
This time it's Condoms
no but really, I have a car battery charger that was plugged into the Cayanne and wife drove out with it still plugged in. Ripped out the power cord so I need to open it up to try and reconnect the cord to it.
Rest In Peace Jaak
Cable Guy
Cable Guy
This set has more than what you will ever need --> http://www.leevalley.com/en/Wood/pag...t=1,44047&ap=1
I've got it and there is no screw head that I cannot defeat. I always check this place out for different types of tools ... toy store +
I've had some luck by using a small flat blade screwdriver, like the ones used for glasses. If you find the correct size it will hold enough to get them loose, then replace with something else. Use pliers to give you some grip on those small screwdrivers but not too much.
Fleabay. Tools will be low quality but would last at least 2 uses.....charger and 1 condom machine.
Here is an example: http://www.ebay.ca/itm/4-Piece-Preci...#ht_2417wt_922
