Late 944 Control arms?
Hi guys,
So I just got my 944 turbo up to Montreal from NY and I got some bad news on the provincial inspection. The control arm on the passenger side (I think - wheel has some play when pushed at the 12 and 6 o'clock positions - taking it to a garage for final diagnosis) needs replacing. Had a look on Pelican and wow - those things are not cheap.
I am going to be tracking this car so I don't think I should try to rebuild them - thoughts? Where can I get the best price for a set? I should probably do both at the same time, right?
Also, has anyone got the Blaszak Precision control arms?
Thanks for the bump Nick!
I got a set freshly rebuilt with no track time...$500
The only issues with the original arms is if you run big stabilizer bars and drop the car below the 12 or 12.5" bulletin recommended ride height.
