Durametric Scanner Tool - Anyone local?
Pocket Sand
If anyone local has a durametric for the 996, would it be possible for you to bring it to one of the GTG's if you're heading out that way?
Trying to diagnose an alarm fault with the OEM system that causes the alarm to go off without warning.
Thanks in advance.
Thanks in advance.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
What changed to cause the problem?
Pocket Sand
Lol, nothing really.
I used to have the "occasional" false trigger (read once ever few months) but now the problem has gotten much worse. Had an aftermarket head unit put in, but it was done by someone competent and was not the cause of false triggers.
Now it's gotten quite bad (without having made any change to the car), and oddly enough, it sounds like the alarm is "dying" because it'll start to go off, then start honking inconsistently, before quieting up completely (lights will still go off). My biggest issue, apart from the noise is that last time this happened, it also took out the 7.5amp fuse in the box under the seat which is on the same circuit as central locking and interior lights so if that goes, you have to replace it to recover your locks and lights.
Pocket Sand
Only a little bit...that microswitch or regulator might have something to do with it...that problem still happened a few months if not a year or so before the alarm problem became recurring. Will look into it though. Would that also throw an alarm code on the Durametric?
Pocket Sand
^ Thanks. I'll PM you on thursday to make sure I'll be there. Leaving for biz for 2 weeks on sunday so I might just spend saturday at home.
