993 cam timing tools
Very close to finally getting the engine back in the car. Does anyone know where I can find 993 cam timing tools in Ontario, or a good place to buy in the states. Looking for Tools 9551, 9552 and 9582.
Thx
Thx
Did you find any? You can manually do it the old fashioned way, lift is 1.0mm TDC I think on the NA cars, not sure about the Turbo.
You can always backdate your sprockets and machine your cams if they do not have the woodruf keyways - that way you have a positive lock on the camshaft, and can use the indexing holes to microadjust to get the right timing.
Cheers,
Mike
Cheers,
Mike
