Intelligent Trickle Charger 60% off ($23.99) @ Cdn Tire
http://www.canadiantire.ca/browse/pr...=1347625328796
Winter's coming.... Looks to be a similar design to the CTEK/Porsche model.
$23.99 (Reg. $59.99)
MotoMaster Eliminator Intelligent Battery Charger, 2A/4A
- Built-in intelligent microprocessor makes charging faster, easier and safer
- Suitable for all types of 12V lead-acid batteries, including gel cell and AGM
- Weather resistant design makes it suitable for use outdoors in wet or extreme cold conditions
- Built-in microprocessor monitors battery status and regulates charge cycle providing a faster, more thorough battery charge
- 4A medium charge for charging large batteries or 2A trickle charge for charging small batteries and maintaining car and truck batteries
- Automatically switches from full charge to maintenance mode to maintain batteries during prolonged periods of storage without overcharging or damaging the battery
- LED indicators display charge status and reverse polarity
- Choose from 3 connection options - standard clamps, ring terminal connectors or 12V accessory plug
- Canadian Tire Warranty:
- This product carries a 3 year exchange warranty redeemable at any Canadian Tire store.
I have one of theses, I used it since 3 years. It's not bad but the CTEK is better (CTEK is listed 89$ tough). In 2A mode, it will do the job to maintain a car battery (already charged). But it is not powerfull enough to re-charge a car battery or a a deep cycle battery. Also, always make sure both end is connected because if it is not plugged in the wall, it will discharge slowly your battery.
Overall, it does the job to maintain a p-car battery for storage, but you still need a real charger for charging. If you want a better one, get the CTEK.
I've got a another battery charger as well. I like the size of this one and want to use it to maintain the battery. During the week the car doesn't get out much
