where do I get high octane gas in downtown T.O.?
Old 08-02-2012, 10:36 AM
71pest
71pest's Avatar
Default where do I get high octane gas in downtown T.O.?
The way I understand the manual I should be using 92 octane, where do I find it?? I live downtown, west of bathurst.
Old 08-02-2012, 12:25 PM
porsche0nut
porsche0nut's Avatar
Hey,
Shell V-Power (91 octane) for our air-cooled cars. The V-Power has no ethanol. I've read that the ethanol degrades the internal seals/o-rings over time.
When I lived downtown I went to the Shell on Bathurst just south of (is it King?) on the west side of Bathurst.
Another good thing about this is that no matter where you are, you can usually find a Shell station!
Old 08-02-2012, 02:06 PM
Zookie
Zookie's Avatar
you need some C16... go to Pearson Airport and tell them you want Fuel Now
Old 08-02-2012, 02:45 PM
71pest
71pest's Avatar
I thought we were to use 92 Octane!?!?
So 91 is fine, all gas staions have 91.
Old 08-02-2012, 02:48 PM
Dale Gribble
Pocket Sand
Dale Gribble's Avatar
91 octane is fine and like others have mentioned Shell V-Power is best.
If you're running a really high boost application, sunoco 94 is probably better for detonation resistance, but it has ethanol, where as Shell 91 V-power doesn't.
Europe and Japan use different octane rating systems so there is equivalence to US/Canadian 91 and 94.
Japan and Europe use a system called RON or Research Octane Number to determine the octane rating of their gasoline, while stateside we use a system called AKI or Anti-Knock Index to determine gasoline's octane rating... Interestingly, to further complicate things it would seem that USA AKI system is actually derived from the average of the RON system and another more complicated system referred to as MON or Motor Octane Number. RON+MON/2 in otherwords for me to find out what 92 US octane means in RON, multiply the foreign RON Octane rating by 0.95 and you will have the US AKI equivalent.
( RON Octane Rating x 0.95 = AKI Octane Rating )
98 RON Octane x 0.95 = 93.1 AKI Octane (US measure)
100 RON Octane x 0.95 = 95 AKI Octane (US measure)
Long and short of it: if your car is stock, don't over think this too much. Just fill it up with 91 octane dino juice and drive.
Old 08-02-2012, 02:52 PM
71pest
71pest's Avatar
Thanks everyone.
Old 08-02-2012, 02:58 PM
911 Rod
911 Rod's Avatar
Why?
Stock these cars take regular 87 octane.
Is it stock?
Old 08-02-2012, 05:17 PM
John 996 TT Cab
John 996 TT Cab's Avatar
The Porsche dealer in Vancouver attributed the codes I threw (before doing the mods) were caused by using 91. When I switched to 94 the code throwing stopped. I was using Shell 91 but to get the 94 had to go to Chevron.
John in Vancouver
Old 08-02-2012, 06:51 PM
porsche0nut
John in Vancouver
John, this is in a turbo, correct?
Turbos run higher compression (youre packing in more air and fuel) and thus need a higher octane rating to avoid pre-detonation. Essentially, the lower the octane, the easier the fuel becomes to detonate by compression rather than spark (which is why diesel is very low octane fuel - no spark in a diesel engine the combustion occurs when the fuel/air mix is compressed enough). Pre-detonation is bad.
In a 3.2, my personal opinion is to go for non-ethanol containing fuel over highest octane. You can also get chips programmed specific to the fuel you are using... Do a search on "Steve Wong chip".
Old 08-02-2012, 06:56 PM
porsche0nut
Oh, I should also mention that not all shell gas is non-ethanol.... Only the 91 V-Power. The 87 and 89 fuels still contain 10% am 5% ethanol respectively.
Old 08-03-2012, 12:22 AM
SToronto
SToronto's Avatar
Received 1,191 Likes on 781 Posts
Originally Posted by porsche0nut
Hey,
Might be thinking Spadina south-bound, one block south of King St. Shell also has an iOS app with a station locator using device GPS. Has come in handy for me.
Old 08-03-2012, 09:51 AM
porsche0nut
Ah yes... you are correct it is Spadina
The iOS app is fantastic... so good you don't need to remember the street names
Old 08-03-2012, 11:07 AM
boman993
boman993's Avatar
No wai! Downloading Shell app right now! I was always relying on searching
"Shell" on my Maps app; but business listings are always "sponsored" so not all
of them pop up in the querry! This is so awesome!! Thanks guys!
Old 08-03-2012, 02:25 PM
pongobaz
pongobaz's Avatar
It's a cool app. Just downloaded it too.
Old 08-03-2012, 02:34 PM
Sciloh
Sciloh's Avatar
For you Android users, It is available as well.....saved me a few times.
Quick Reply: where do I get high octane gas in downtown T.O.?
