Where in Onatrio are you buying oil?
Presently using Mobil 1 0w-40 engine oil, as per my dealer.
However, don't want to use a "0" winter oil in summer (even in Barrie, ON, it never hits -20) so I want to use a Porsche Approved (still have a couple of years warranty left) 5w-40, like: Motul 8100, Pennzoil Platinum Synthetic European Formula or Quaker State Q European Formula. Just doing a quick web-search and cannot find any dealers carrying these.
I am using Amsoil 5W-40. Great oil, been using it for DE's for a while as is my buddy in his Carrere 4 lok up for your local distributor. Ships out of TO. My all up cost in mtl is 9.88 a litre. Great deal for great oil
Just wondering if anyone has found those 3 oils I mentioned, available locally?
WALMART!!! Mobil1 5W40, don't be freaked out about "Turbo Diesel Truck" on label. Just completed BLACKSTONE oil report to verify Zinc and Phosphorus levels, everything was perfect. I think Sports Car Boutique carries Motul 8100, might try out sometime and get stats.
Ok, thanks. Wanted to stay with a "Porsche Approved" engine oil for the next couple of years, until the warranty expires.
I'd heard that the Mobil 1 5w-40 "Truck" changed it's formulation and wasn't as good - your test checked out then? Will check with SCB for Motul, thanks.
I do, yes. The "0" is winter spec'd to about -21 degrees C, which will provide better protection, at that cold temperature, on a cold start. In Summer, I don't feel that's necessary. I'd rather have the protection at the higher end of the temperature scale.
Captain Obvious
Super User
Super User
